Greg Rozar AKA- CubDieselFan
Old 12-08-2017, 07:18 PM
Vrobert's Avatar
Vrobert Vrobert is offline
Just replaced the incorrect blade lift bracket with a new WF bracket for my 1811. Wow, I popped a grin when the hydro lift raised the blade up for the first time. This is my first tractor too.
And it was just in time because we have 3-6" coming tonight in Southern MD. Do I need to install my chains or weights for this much snow? I have decent turf tires and a 100' paved driveway.
I know I could shovel it but I broke my toe recently. That's my story and I'm stickin to it!
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 12-09-2017, 08:59 AM
jbrewer's Avatar
jbrewer jbrewer is offline
I kept Lew in hamburgs for a while by ordering a 161 short block to end up in O #2
Does that count?
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-15-2017, 12:22 PM
Installed fresh brake pads & shoes on the 149 loader project along w/stainless slider rods from Jeff
Old 12-15-2017, 02:10 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Looks good! Should work nicely.
Queen Of The Quietlines!
Old 12-20-2017, 07:07 PM
I got the 1050 ready for the snow, today was the first I've started it since spring and it fired right up and runs great. When I change the oil I could smell a hint of gas so I plan to order a new fuel pump for it tonight, once the pumps on it will be ready for some snow.
Old 01-05-2018, 02:55 PM
DownNdirt's Avatar
DownNdirt DownNdirt is offline
Yesterday i picked up a ton of accessories. cub sleeve hitch casitng with lift bar and rear end bracket, 42 blade, WF spring assist and side covers. Thought i got a good deal at $300. Then i swapped out the wrong plow for the right one. Now i just need to find hardware for the panels and find my hydro leak coming from the front side of the transaxle and fix the slop in the trunion (that i thought i already fixed).
Edit: I added some better pics but as usual, the forum doesnt like it and wants to flip them.
'78 1250, '79 1450
Trapped and released: 124, 1000, 72, 1211
(JD) '86 316, '70 140 H3 patio yellow, '74 140 H3, '86 330 diesel, '87 214
Attachments: Brinly plows, cultivator, kk-300 planter, many mower decks, #2 cart, #1 tiller w/ 2 exts. & #1a w/ 2 exts, , JD 50 & 80 (3x) carts, 2 JD 54" blades, IH 42" blade, 3pt disk, several sleeve hitches, too much stuff to list!
Old 01-05-2018, 05:09 PM
jbrewer's Avatar
That's a nice stash of accessories you've got for your cub!! Contrats
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 01-05-2018, 06:51 PM
I could not move the 1861 when I went to the shack to push it out, frozen tranny on a stick, did the heated dipstick thingy and in a few hours it was moving again.
Got it running and did some snow duty, then I changed the hytran and filter in it, old fluid came out like chocolate milk but you can't drink it.
Up to 530 and counting...
Old 01-13-2018, 10:59 PM
JPWright JPWright is offline
Default I split the 100
The shifter forks needed some attention so I had to pull the transmission out. It took all day to get it apart and back together but it is once again ready for snow.
A 122 with weights and a deck for mowing trails.
100 with loaded ags, three point for ground engaging brinly cultivator, brinly disc, thatcher, cart.
Elec Trac E15 for finish mowing.
Old 01-20-2018, 05:17 PM
Chardie Chardie is offline
Default 125 resale project
Pulled the engine and disassembled it so I can get the crank to the machine shop to be turned. Turning out to be a not for profit project. I’m not a hydro guy so I have no plans on keeping it. Was hoping to make a little to fund other projects. Bahahaha
