2182 rear axle brace?
I got a set of the sgt rear axle braces for the 2182, i know im asking a dumb ? But can someone post a few pix of the frame part of the brace installed. It dosent seem to line up with any holes on the frame and i wanted to make sure i did it right the first time. Dont want to drill unnecessary holes.
Thanks |
Sam will be along soon. Do you have the front Haban mount? IIRC that is where the front of the brace hooks to. You shouldn't need to drill anything.
Omg , yup see told you i had a dumb?
I see it now thank you. |
This is from Sam's thread on the braces.
Apparently, it comes with a new bracket to replace the original Haban one? http://www.onlycubcadets.net/forum/s...1&postcount=45 |
Yea, i figured it out. I just needed that click in my head you provided. Got em mounted up and working. Thanks.
This is how it goes together. Make sure you put some sealant on the bolts that go into the axle tube.
Am I correct in assuming that those rear axle braces are to keep the nose of the tranny from turning up and breaking the front mounting points? Mr. Sam, where did you get those drilled rotors?
Don B, USAF 1962-1968, Ft. Wayne, IN |
The drilled rotors are what come on the Cyclops Supers. Not sure about older Supers.
My 2072 has regular rotors.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
Maybe the Cyclops are faster so they need vented rotors like a race car..... LMAO
