Greg Rozar AKA- CubDieselFan
Old 03-13-2018, 09:46 AM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default Intermitent voltage to pos. terminal coil 149
I am almost ready to put my rebuilt engine back in my 149 tractor. Before I do, I need to fix a electrical problem. Battery has 12.7 volt between terminals. When I turn ign. switch to ign., it has 12.7 at end of black wire going to pos. coil. When I turn key to start and hold it there, the meter will some times show 12.7 volt and then it shows .1 volt at black wire going to pos. coil. I have studied the wiring diagram till I am blue in the face. I can't figure how the voltage gets to the black wire to pos. coil in the start position. I don't think I need to tell you I don't know much about this. I am sure you have figured it out by now. All help will be appreciated from you members in the know. Thanks and have a great day
Bob
Old 03-13-2018, 10:17 AM
mickb72 mickb72 is offline
I'm guessing he's going from ing to start position and losing volts. Bad key switch. Did i ever say i hate key switches, old ones are even worse. Mike
Old 03-13-2018, 10:30 AM
ironman's Avatar
ironman ironman is offline
Bob
You should always have the same voltage as your battery reading on the lead that goes to the positive pole of your coil in BOTH the start and run positions of the key. Two exceptions would be....
1. You have a bad key switch or....
2. You have the engine installed, the lead is hooked up to the positive pole of your coil and your points happen to be closed. In this case, the points are applying a ground seen through the coil therefore your voltage reading disappears. You should see battery voltage when the points are open.
Old 03-13-2018, 03:04 PM
Old 03-13-2018, 04:36 PM
Mr Bob's Avatar
Default 149 Ign. Switch
Took the ign. switch off from the dash. Thought I had bought a Indak switch when I bought it new about 3 years ago. Looks like I have a cheap one as it does not say Indak any where on it. Where do you buy you ign. switches. Cub Cadet has them for $50 plus shipping. The three wire harness (New) felt a little loose when I pulled it off the switch. Going to garage and see if I can tighten it up a little and see if it makes any difference. Thanks for your help.
Bob
Old 03-13-2018, 09:42 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default switch
The ignition switch itself is responsible for providing the voltage from the battery to BOTH the starter solenoid AND the black wire to the + side of the coil while in the cranking position. You can test this with a voltmeter but that's the way its designed to work
+12 needs to be at the coil during the run position, and in the crank position. It's removed of course when the key is in the off position.
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 03-13-2018, 10:11 PM
Bob
Wanna know a secret? Indak is pretty much a cheap switch.
You can buy ignition switches at a lot of places. TSC, CCC, Ebay, auto part stores.... just make sure you get the correct one for your tractor. That's the important part.
Thread Tools
Display Modes
