cub cadet 1730
pedal switch and seat switch same one nc contacts and one no both alternate when depressed so cold and windy hard to work on it broke in yard trailer full of sticks lol thanks
push to garage where warmer use test light to see where power it doesn't have easy peezy
cub cadet 1730
ordered switch got it today same-thing not that easy and i cant read wiring diagrams what is the next thing to check i am lost
cub cadet 1730
you mean like idiot lights that steers you wrong lol
Did you check for loose or frayed wires? You could probably find a video on YouTube about how to use a test light. That would be the best way to find your problem.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart |
Something like that
On my 1620, ( same lt basically ) I have to pull the motion lever "in" toward the seat. The lawn tractor starts then. I did bypass that seat safety switch.
Did the tractor stall or did you just turn it off and it won't start anymore?
cub cadet 1730
turned it off to move sticks now nothing going to try to work on it some more tomorrow just trying to know what to look for thanks
I would try moving your drive lever. Sometimes they don't go into neutral, move it to reverse and back and see if that works. I would also check the wires aren't loose or frayed.
Good Luck!
