Greg Rozar AKA- CubDieselFan
Old 02-28-2018, 02:59 PM
Marko141's Avatar
Marko141 Marko141 is offline
Looks like a broken rockshaft to me....
That's what I saw, broke right in half, bought it that way, not sure how one could manage that...
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 02-28-2018, 03:21 PM
cubs-n-bxrs's Avatar
Stuck filters are a PITA. Last one I had that was stuck I pounded a large screwdriver all the way threw it around the middle and gave it a slow steady twist and it broke free. Your results may vary. Good luck
Old 02-28-2018, 03:22 PM
Ya got good eyes Lew!!
Better than mine as I missed the front braces on that loader earlier in another thread!!
You are turning that filter counter clockwise to unscrew, right Marko??
Old 02-28-2018, 04:16 PM
Marko141's Avatar
Why yes sir, it's just stuck on there really good. Any telling on the age of that filter? Not sure what the original filters looked like.
Old 02-28-2018, 04:17 PM
Marko141's Avatar
And we are expecting 10" of snow tomorrow... be nice to use the blower!
Old 02-28-2018, 05:03 PM
ironman's Avatar
ironman ironman is offline
Originally Posted by Marko141 View Post
So I am having some issues with my oil change. So far I did not intend to change my oil but when I removed bolts to add the gear box oil started to poor through the holes and when I tried putting the bolts back in there would only go back in about half way. So I have some questions:
Are all the bolts holding the cover on suppose to be the same length? I have 2 different sizes.
Also I can not get the oil filter off, I assume it's just the normal filter that screws on but I can not tell. I got the replacement 1410 filter from
NAPA and it looks like I should screw off.
if anyone knows the correct length of bolts that should be in the rear end without me looking through pages of manuals would be helpful.
This is not rocket science math. The holes it the casting (7 of them) are all about 1" deep. You NEVER want to put a bolt in them that would bottom out because you would break thru the casting and you are screwed. So if you were only putting back on your cover plate alone, you would use seven 3/4" long bolts. But let's say you want to have a draw hitch plate. Well you want to use a little longer bolt in order to catch enough threads so probably a 1" bolt in the three holes for that would be fine. But now you also want to add the tiller gearbox plate which is about 1/4" thick so you would add another 1/4" to the length of those three bolts holding on the tiller and hitch. Or in other words, 3/4" bolts in the top five holes and 1 1/4" bolts in the bottom three holes.
Now as to the filter, if you can't find a tool to get it loose, take a sharp chisel and a light hammer and start tapping the chisel blade into the heavy rim of the filter where the red line is. Once it has a good bite, angle your chisel so that you're tapping the filter in a counter clockwise direction. Don't beat the snot out of it, you are only trying to loosen it. If your chisel loses its bite start a new one
Old 02-28-2018, 06:42 PM
Marko141's Avatar
Just going off what I have, someone botched it up and I'm fixing it little by little. I take stuff off, make sure I have what I need, find what I'm missing. Kinda hard to tear everything apart at once while I'm trying to use it which slows the process. Anyone have a reference for spray paint that comes close to matching the white and yellow? I'm just going to do a few pieces like this cover and gear box. TSC has paint that specifically says what it's meant to replicate but I couldn't find a CC one.
Old 02-28-2018, 07:15 PM
twoton twoton is offline
...pounded a large screwdriver all the way threw it around the middle and gave it a slow steady twist and it broke free....
X2......
Old 03-01-2018, 11:55 AM
Marko141's Avatar
Well I got after the cub again today, I found on older style oil filter wrench. This one was able to be opened up, so I slapped it around the filter, bolted it back together, gave it a few cranks and it popped free! Threw on the 1410 filter from NAPA and now I'm just waiting on that gasket.
Old 03-01-2018, 11:56 AM
Marko141's Avatar
Victory photo, don't know if I should toss this thing or keep it as a trophie lol
