#61
Though I have a couple of QL's, I must say that on looks alone, the 1X8/1X9 wins that battle..... IDK why, but I have always liked them better.... though I like the electric PTO clutch on the QL's, better than the 1X9 setup.
#62
John
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
#63
Are those Heim joints you used? When I got my 1650 a year or two ago, I simply hammered the steering joints on an anvil to take the slop up a little. But I'd like to replace with Heim joints. What part number(s) did you use? Thanks, Andy |
#64
Steering: (4) 3/8"-24 Internal Thread-Right Hand Shank # 4444T931 Hydro Control Linkage: (1) 5/16"-24 Internal Thread-Left Hand Shank # 4444T922 Hydro Control Linkage: (1) 5/16"-24 Internal Thread-Right Hand Shank # 4444T921
http://www.solunagarage.com |
#65
Keep at it John! Yours will look much better than mine when you're done.
#66
Installing tubes so I can fill the rears
#67
Thank you! Andy |
#68
Some upgrades in prep for the season:
Bosch epoxy coil! Also reworked the mule drive, repaired areas of the shaft that had worn out, repaired pivot points and other areas where 40 years of use had taken it's toll, and added a greaseway between the tensioner and idler.
#69
Good to see your progress.
#70
Nice job on the 1250; like reading all the updates. I'm working on my own 1250 right now, Gettin' the old girl saddled up for mowing and gardening season. These QL's look great and work even better IMO. (Might be a tad bit biased because it was my first cub cadet.)
'78 1250, '79 1450 Trapped and released: 124, 1000, 72, 1211 (JD) '86 316, '70 140 H3 patio yellow, '74 140 H3, '86 330 diesel, '87 214 Attachments: Brinly plows, cultivator, kk-300 planter, many mower decks, #2 cart, #1 tiller w/ 2 exts. & #1a w/ 2 exts, , JD 50 & 80 (3x) carts, 2 JD 54" blades, IH 42" blade, 3pt disk, several sleeve hitches, too much stuff to list! |
