Greg Rozar AKA- CubDieselFan
Old 09-30-2017, 03:40 PM
dbuck dbuck is offline
Smile LT1050 fuel problem:
Having trouble pulling fuel from the tank to the filter. New filter and fuel pump. I can take the filter off the line from the tank, put a piece of fuel hose on it and put it my gas can and it will pump fuel. But when I hook the filter back up to the line coming from the tank, it will not pull fuel. I blowed air back thru the line to the tank and I can hear it moving the gas around. Their is a 1/4 tank of fuel. Any ideas/suggestion on what the problem might be, will be greatly appreicated.
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 09-30-2017, 04:17 PM
Are you using the correct fuel filter (KH25-050-22-S1)...???
Roland Bedell
Buy: Made in the USA
Old 09-30-2017, 06:04 PM
Don, dumb question but is the filter installed the correct way? Most have a directional arrow on them or say "flow" with an arrow. Does yours?
Old 10-01-2017, 10:15 AM
Smile
No, Napa 3011.
Smile
Yes, filter is installed the correct way.
Old 10-01-2017, 12:58 PM
Have you checked the filter for obstruction? Seems like the most obvious of problems. Just because it's new doesn't mean it isn't defective.
Old 10-01-2017, 05:00 PM
Smile
I pulled the filter off the line from the tank and put a piece of line on it and stuck in my 5 gallon fuel can. It pulled fuel just fine. Engine fired up and ran just fine. So I do not think it is the filter.
Old 10-01-2017, 08:17 PM
Well, then the fitting in the tank must be plugged. Take it out and inspect it.
Old 10-02-2017, 06:41 AM
Leave the filter installed and see if it will pull from the "gas can".
Roland Bedell
Old 10-02-2017, 12:03 PM
Terry C's Avatar
Terry C Terry C is offline
I agree but don’t try to clean it up just replace it. They are cheap.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
