Greg Rozar AKA- CubDieselFan
Old 03-07-2018, 12:02 PM
Dirty Steve's Avatar
Did not realize Messick's still had the kits. Cub says NLA.
I will have enough parts/o-rings/wiper seals to rebuild 6 cylinders for closer to $35.
This cylinder I am working on is not perfect. But it has friends in the shed in better condition. And now I gots the parts figured out by stripping this rusted up cylinder. It's usable but the 2 or 3 pits in the rod concern me because I think one or two pits in the chrome will phass by the 3/4 o-ring below the wiper seal. I totally agree Jon, won't take long...
However, after messing around for a couple of hours, the info is now documented. I did find a detailed rebuild thread on MTF from a couple years back but there were NO part numbers unfortunately.
The gland nut wrench I borrowed from my Dad was a CTA 8600. In the neighborhood of $30.
The cylinder IS still available NEW from manufacturer.
http://www.customcylindersintinc.com...ift-cylinder-0
Certainly if a person did not have access to speacialty tools then buying a new cylinder is much more palatable at that price point.
Old 03-07-2018, 02:07 PM
I give you a lot of credit for rebuild it. Even if it doesn't last at least you know how it comes apart.
Old 03-07-2018, 04:22 PM
sorner's Avatar
sorner sorner is offline
Good job on that. (even if it doesn't last). My 2284 power steering cylinder rebuild is still holding strong. I have not leaked a drop of fluid. I've been using my tractor all winter blowing snow and taking my two year old son for rides around the yard. Where there's a will there's a way... Oh, and I have an extra lift cylinder in my garage in perfect condition... just sayin.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 03-07-2018, 06:13 PM
Don't forget McMaster.
#330 -- https://www.mcmaster.com/#o-rings/=1bve7hl
#210 -- https://www.mcmaster.com/#o-rings/=1bve7sg
#141 -- https://www.mcmaster.com/#o-rings/=1bve82j
Rod wipers -- https://www.mcmaster.com/#rod-wipers/=1bve8iw
Thanks for the write up Steve.
Old 05-04-2020, 12:50 AM
WEL58's Avatar
WEL58 WEL58 is offline
Tried the McMaster links but they do not get to the specific o-rings.
Assume these where the o-rings to use...
Dash
Number ID x OD ID x OD Hardness Specifications Met Temp Range, °F Color Qty. Item# Price Pkg.
Wd.: 3/32 Fractional (0.103" Actual) --> Front Head to Cylinder
141 2 5/16 x 2 1/2 2.300" x 2.506" Durometer 70A (Medium) ASTM D2000, SAE AS568, SAE J200 -20° to 250° Black 50 9452K147 $8.38
Wd.: 1/8 Fractional (0.139" Actual) --> Rod Seal
210 3/4 x 1 0.734" x 1.012" Durometer 70A (Medium) ASTM D2000, SAE AS568, SAE J200 -20° to 250° Black 100 9452K29 7.57
Wd.: 3/16 Fractional (0.210" Actual) --> Piston Seal
330 2 1/8 2 1/2 2.100" x 2.520" Durometer 70A (Medium) ASTM D2000, SAE AS568, SAE J200 -20° to 250° Black 50 9452K49 12.96
Will need to figure the rod wiper.
Bob G.
