Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 04-06-2015, 05:30 PM
ford4150's Avatar
ford4150 ford4150 is offline
Default Nikki 2 bbl carb
this carb is on a 20HP Vanguard. Has 3 hose connections. Two on top, one on bottom. Top left is fuel inlet. What connects to the other two?
Old 04-07-2015, 11:48 AM
No idea. But did you bead blast that?
Old 04-07-2015, 01:27 PM
ford4150's Avatar
Bead blast: No, shot the outside with aerosol carb cleaner. The bottom half went in the ultrasonic cleaner.
I think they're atmospheric vents, maybe not.
The bottom one isn't shown on any figures in the B&S manual.
It doesn't have a float bowl drain screw. One is shown in the manual.
Haven't tried to start the motor yet. Still accumulating gaskets & seals to put it back together.
Old 04-07-2015, 01:28 PM
I would have guessed they were just vents, but I'm not very up on the Vanguards. Didn't figure they were vacuum lines.
Old 04-07-2015, 01:31 PM
I would call Vanguard and ask them.
http://www.vanguardengines.com/
Old 04-07-2015, 04:36 PM
ford4150's Avatar
Sam, Thanks for the link. Sent them an email. Should hear something within 3 days.
Old 04-09-2015, 06:21 AM
twoton twoton is offline
So hey ford4150, What do you have for an ultrasonic cleaner? I was thinking about this one;
http://www.amazon.com/dp/B002QD624C/...I22ENB0APW5DBO
couldn't justify the cost when I can usually do a pretty good job by hand, but it might be nice to have.
Old 04-09-2015, 06:56 AM
ford4150's Avatar
I have this one. Happy with it. Big enough for small engine work.
Old 04-09-2015, 07:39 AM
Looks like a good sized unit. How's the noise level? What do you use for solution?
Old 04-09-2015, 08:17 AM
ford4150's Avatar
size is 3L. Just sort of hums- not loud. Solution depends on what I'm cleaning; pine sol, simple green, lime away, purple power. Nothing volatile. Do a google search for whatever metal is going in. I think it was simple green that turned aluminum black. For carbs, I soak them in gunk carb cleaner first.
