Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 10-22-2014, 07:21 AM
Originally Posted by mike44107 View Post
If so what would you suggest?
I would suggest you resist the temptation for further tinkering as long as it's running well.
Old 10-22-2014, 08:05 PM
mike44107 mike44107 is offline
Try a set of Auto Lites. My Van Guard would not run more than 20 hours on a set of champions. It was never the same cylinder.
I may just do that when my Champions start to go.. They have less then 20 hours on them and still look like new (sharp edges).
Old 10-22-2014, 08:25 PM
Probably the best words of wisdom..
I no doubt need to fix that slack in the exhaust valve, but other than that perhaps it will be ok..
Old 10-23-2014, 12:24 AM
Better check that slack. I can't remember which engine, but I've seen the stud pull out of the head on the rocker. May have been the Kohler V-twin, but it may have been the Vangaurd... I don't remember.
Old 10-23-2014, 03:12 PM
I finally checked it a little bit ago. Popped open the valve cover, noticed the push rod moved out of position.. Like the top ball was no longer pushing in that little cap on the screw it was resting in the edge of the actual rocker.. Once I popped it back in place and checked slack it was within tolerance. Oddly this happen once before last year.. completely popped out of place.. Engine started back firing hard..
But I started it up and running fine still! Hope it stays that say!
Old 10-23-2014, 05:02 PM
If the push rod is popping out of the rocker you have some sort of problem. My guess is you have a valve hanging up. Or you have an over heating condition causing the valve to stick in the open position. I suggest that you find out what is causing the problem before it gets more expensive. Did you check the valve clearances, or did you just pop the push rod back in place?
Old 10-30-2014, 08:10 PM
I honestly just pushed the rod back in place.
I set the valve clearance last year.. thinking it was still ok.. The engine has less then 30 hours since I adjusted all the valve clearance.. Maybe I screwed up on that valve and should redo it..
I probably should also double check that the push rod is not bend as well. Some reason I recall an issue with the rockers and push rods on these models..
Another question.. Sorry I have so many!
I noticed with the oil fill cap off and engine running.. Lots of air was blowing out! I assume this is probably do to failing head gaskets? I am not too worried.. I don't have a pressure tester anymore.. but I figure it's piston rings or head gasket.. and since the exhaust is not blowing smoke.. I assume the better bet is head gaskets.. My assumptions good on this?
The task does not not look too bad.. Should be fun.. When I get some time I'll purchase the new head gaskets..
Thank you all again!
