Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 05-08-2013, 10:51 PM
lowes48 lowes48 is offline
Default Help With My 1440 Oil Leak!
Hey Guys,
Got the lawn mowed today before the rain hit but even though I ended up with the best looking cut I've had so far this year my 14hp Vanguard started puffing oil smoke every now and again while mowing. I stopped, removed the side covers and found that there was a lot of oil on both covers and it appeared to be coming from somewhere near the crankshaft and drive pulley assembly. I thought it might be a loose oil filter but it was tight, so that means the oil is coming from somewhere else...
After checking the parts diagrams today I assume the oil could be coming from a failed crankcase cover gasket or outer oil seal but I couldn't get a good idea of where the oil was coming from exactly due to the shrouds, grass and crud. I removed the hood, grill, shrouds, and other sundry stuff so I could get a better idea of what needs to be fixed but I didn't have time to degrease the engine and wash everything.
All that being stated I just wanted to ask what you guys think might be suspect so I'll know where to focus my efforts, and I also wanted to ask if this would be a hard fix, which if it's either of the parts mentioned earlier I think I can handle it!
Thanks in advance for the help!
Old 05-09-2013, 07:55 PM
My guess is a bad front seal but you will need to find out what is leaking before any of us can help.
Old 05-09-2013, 10:28 PM
Got her clean this afternoon and ran it around a bit to discover that it is the front seal. Now can any of you guys tell me what I need to order? just a seal and a crankcase cover gasket, or does the job require more stuff?
Thanks again for your help!
Old 05-10-2013, 07:05 AM
You should be able to put a couple screws through the seal and pull the old one out without removing the front cover. You will need a tube of some sort that will fit over the crank shaft to drive the new one back in. I would not remove the front cover if it was me just to change that seal.
Old 05-10-2013, 08:11 AM
Thanks, Sam! I think you just saved me a lot of work! I'll order the seal today!
Old 05-15-2013, 11:57 PM
Got the new seal in this evening and let it run for a few minutes to verify the repair was a success. I got everything buttoned back up and she's ready to mow tomorrow! Got to love a $6.00 fix! Thanks again for the help, Sam!
Old 05-16-2013, 06:19 AM
Glad to help, that's why this is the Number 1 Cub site.
Old 05-16-2013, 06:27 AM
Glad to hear you got it fixed and fixed cheaply!
Old 05-16-2013, 11:13 AM
X2!
Proud owner of my Original!
Old 05-16-2013, 11:39 PM
Thanks again guys! Mowed this evening and all is well! Now it's time for a set of v61 tires up front and I'll be good for a while!
