Greg Rozar AKA- CubDieselFan
Old 03-14-2018, 03:31 PM
sorner's Avatar
sorner sorner is offline
This is a perfectly timed thread. I have a spare steering unit in my garage that leaked like that, and I plan to rebuild it in the spring.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 03-19-2018, 12:56 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Well, I received my kit this week and attacked the orbital on Saturday. Would have been done in about 45 min, but I got cocky on the last segment going back together and the Jesus Springs ended up setting me back about 40 minutes. So all in all, after torquing the unit together, bout 1.5 hours total.
Decided to try it today after installing the lines last night. To my amazement, large streams of oil did not appear, and the steering wheel actually moved the wheels correctly. I'll check it out better after the whole tractor is pressure washed.
The thing operates really smooth and sounds better. It also doesn't make that strange noise when hitting the end stops.
1- 1200 in pieces
1- 1864 in pieces
Old 03-19-2018, 05:06 AM
Dirty Steve's Avatar
Good work, Sir!
For everyone who has rebuilt a steering valve. Do you put new springs in or just the orings?
Old 03-19-2018, 07:17 AM
Well done
Old 03-19-2018, 07:37 AM
Ya did good junebug.
Always like a "happy ending"
Old 03-19-2018, 10:02 AM
Good job! What kit did you end up getting? FYI, it helps to have an ice cold beverage while rebuilding those.
Old 03-19-2018, 11:47 AM
DieselDoctor's Avatar
It's not as bad of a job as some think. Except for the springs you sailed right through it. Good work!
Old 03-19-2018, 05:35 PM
taylorjm taylorjm is offline
Ordered my seal kit....and a new set of springs....just in case!
Old 03-19-2018, 07:03 PM
Rescue11's Avatar
Originally Posted by Dirty Steve View Post
Good work, Sir!
Thanks Steve! Kit just came with O-rings.
Well done
Thank you Sam!
Thanks George! Happy ending...photo finish... It all feels good at the end
Yup, except... I had 3 o rings left over. But my valve ports only used 4 seals, it doesn't have a relief, so that for sure eliminates another. So the only thing left is the one remaining small o-ring...
Thanks Oak, and thank you for the guidance. I actually forgot to call Messicks so I was stuck with the $107.00 kit by the time I got the order confirmation. I actually had 6 beers, which is partially why I'm surprised it works
Thank you much! And thanks for guidance aswell! Hopefully the next one will go faster, but still not bad considering a new orbital is 600+
1- 1200 in pieces
1- 1864 in pieces
Old 03-19-2018, 07:13 PM
Good job finding the springs and your completion of the repair.
What is next?
Up to 530 and counting...
