Greg Rozar AKA- CubDieselFan
Old 04-09-2018, 11:02 AM
Jjsmit02 Jjsmit02 is offline
Default Piston protrusion K161
Well I finally started to rebuild the 70. Went on eBay and bought a overhaul kit for the k161. Tore it down cleaned and honed it. Put it back together (mostly) because I believe I have a k181 rod instead of a k161. So the piston is sticking out of the block at TDC. Just looking for confirmation. Your collective wealth of knowledge is needed.
Old 04-09-2018, 11:17 AM
I've never seen a piston stick out of the block on any Kohler I've ever worked on. I would suspect something is wrong. Most Kohler heads are flat where the piston is so if the piston sticks out of the block it will probably hit the head. How much is it sticking out?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-09-2018, 11:20 AM
Terry C's Avatar
Terry C Terry C is offline
You have the wrong connecting rod. 8hp rods are shorter. About 1/8 approximately.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-09-2018, 11:39 AM
It's about 1/8 of an inch so I probably need the 8hp rod. The engine was rebuilt before.
Old 04-09-2018, 11:49 AM
Thanks for the input, I guess it would have been a good idea to compare the two rods before I started.
Old 04-09-2018, 11:56 AM
Just run two head gaskets.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-09-2018, 06:21 PM
No need to take it apart, just hit the top of it with the chain saw, then polish it up with the snag grinder.
Being soft aluminum, it will cut pretty easy
Old 04-09-2018, 11:32 PM
I was going to suggest a block of wood and some sandpaper but your way works too.
Pap's 100
Restored 108
1211 Dual Stick
1050
