Greg Rozar AKA- CubDieselFan
Old 11-17-2017, 01:03 PM
Userj8670's Avatar
Default Elec PTO on 1x8/9 series
Any one ever put an elec pto on in place of a manual?
Old 11-17-2017, 01:09 PM
It can be done but only if the the block has the threaded holes to bolt the PTO on.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-17-2017, 01:18 PM
Lanceskene's Avatar
Lanceskene Lanceskene is offline
There is also at least two differant bolt patterns that Im aware of. K341 is bigger maybe???
Lance / Alberta Can
IH 127 w/deck, snowblade
IH 154 Loboy(x2) w/creeper 3pt and 3160 deck
CCC 12.5 w/deck
Plus 35 or so non IH tractors
Old 11-17-2017, 01:39 PM
Userj8670's Avatar
Well I have a 169 - I assume then I'd have to drill the block?
Old 11-17-2017, 01:41 PM
If it's the original engine then you would need to drill and tap the holes, if it's been replaced it's probably already tapped. What's wrong with the mechanical PTO?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-17-2017, 05:39 PM
Userj8670's Avatar
Nothing is wrong with it. But let me give you an idea where my heads at. I am confident your familiar with the 364 blower which (with a 418 kit) attaches to a quietline. I have a 418 kit off a 1650 and wanted to see how it fit on the 169. It fits well but the idler pulley on the kit hits the arm for the engage/disengage. Thus if I had an elec PTO I could remove said hardware and theoretically be good to go.
This is all brainstorming at this point **
Old 11-17-2017, 05:57 PM
ironman's Avatar
ironman ironman is offline
I'd be assuming your 169 starts with a starter generator (maybe not), but if you drilled and tapped and replaced the manual pto for electric, how would you start your engine or charge your battery??
Old 11-17-2017, 06:21 PM
Good point, I didn't even think of that when I responded earlier.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-17-2017, 09:26 PM
sawdustdad's Avatar
Easy solution. Just buy a QL cub cadet.
Old 11-21-2017, 02:56 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Probably the easiest, and most cost effective option.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
