CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 04-28-2016, 03:49 PM
Sam Mac Sam Mac is online now
ok,
I do not have that starter in my hand, I was speaking of what normally happens.
inertia/helix engages it and over running disengages it, like others have said.
something has to keep it out of the ring gear, I would think.
But I have been wrong, and my wife likes to remind me of that
Yep, that would be DA SPRING! Also they have a few different designs for the Vanguard starters depending mostly on if the ring gear is aluminum or steel. You really need to have the engine numbers to get the proper one. The early aluminum ring gears were replaceable but they are NLA. I had to buy a used flywheel just to get the proper ring gear for one then drill out the rivets, then drill and tap my flywheel in order to bolt the used gear onto it. Think I have a thread about here someplace, I'll try to dig it up.
Old 04-28-2016, 04:12 PM
https://youtu.be/xlqIdpfbHrE
these 2 came out of 2 different 16hp vanguards
Up to 530 and counting...
Old 04-28-2016, 04:20 PM
Ha,LOL!
Run into something like that on a toro self propelled hand mower,tejunkski power TNT 120.
bought it in maybe '72 for Mom, has a 12V starter on a 20" mower.
Mom was around then, and she liked the key starter, as she could not pull the rope.
Long story short it liked to eat nylon starter pinions.
So I found a metal pinion. no more pinion problem till it knocked a tooth off the aluminum flywheel/ ring gear.
so much for that idea.
That old mower is still in the barn, like a lot of stuff I need to get rid of.
Old 04-28-2016, 04:37 PM
Ha,LOL!
If you use the steel pinion on an aluminum ring gear, you'll shell the teeth off the ring gear.
I believe the steel pinions and the plastic pinions have a different pitch between the teeth as well.
Old 04-28-2016, 04:39 PM
The starters I have all look (should look like) the ones on the right. I think the ones on the left are later.
All my 16 Vanguard starters are off 1990's 1641's .
Old 04-28-2016, 05:08 PM
This mess came out of a late 1641. I was told it was a good runner and just needed a tune up, yeah right. Anyway looks like it had been run hot, one of the exhaust guides had walked up in the head and jammed the valve, 2 bent push rods, 2 missing teeth on the ring gear and no teeth on the starter. Fixed it and put in my pressure washer.
Old 05-06-2016, 09:07 PM
Dirty Steve's Avatar
Sam, I get a kick out of that power washer with the dual fart can exhaust.
Old 05-06-2016, 09:12 PM
Oh, back to the topic. Here is the starter out of the 1440 I just sunk too much cash into. $20 some dollars for the new gear drive kit. That one had some mangled teeth.
Old 05-07-2016, 06:22 AM
I got a B&S dealer to break up two starter drive kits and sell me just the spring, cage and retaining clip. I didn't need the rest of it.
Thread Tools
Display Modes
