Greg Rozar AKA- CubDieselFan
Old 12-28-2010, 10:14 AM
sfaulkner's Avatar
sfaulkner sfaulkner is offline
Default K161 issue
While removing the muffler from a K161 engine the pipe broke off in the block.What is the best way to get that out? Here are some pics.
Old 12-28-2010, 06:53 PM
mmzullo mmzullo is offline
Get a hack saw blade and cut the pipe a little until you start to see the threads. Don't do to deep or the exhaust will leak around the threads. Get a pointed punch or center punch and work the pipe to the center of the port. I've done it this way with great success.
Good luck!!
Old 12-28-2010, 07:25 PM
sfaulkner's Avatar
Thanks for the info. What size is the hole, would you run a tap on the threads?
Old 12-28-2010, 08:04 PM
I believe it's 1" NPT. I doubt you have one of those taps around, and they are not cheap. You can make a crude thread chaser by cutting a slot in the end of a piece of threaded pipe. That's probably clear as mud. I don't have a picture to describe what I'm talking about.
Old 12-28-2010, 09:22 PM
sfaulkner's Avatar
I don't have a tap that big, but I have a friend that might. The threaded pipe with a slot in it is a great idea and much cheaper than a 1 inch tap.
Thanks!!
Old 12-29-2010, 09:33 AM
Sorry about the Ebonics from my previous post. I corrected the missed spelled words. I think.
But any way if you can't find a tap use a correct size pipe and back cut a groove like someone had stated but cut it on an angle. I use a wiz cutter. Like a circular saw blade tooth. USE COPIOUS(big word) AMOUT OF LUBE!!!!
Good luck!!
