CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 03-31-2016, 04:42 PM
Dano73 Dano73 is offline
Default V-twin command engines
What are some good ways to get more power out of a V-twin command without a lot of high performance parts? We aren't allowed many performance parts. We are allowed to bore .030 over and an open duration .245 lift cam and thats about it. Thanks for any help.
Old 03-31-2016, 05:01 PM
jimbob200521's Avatar
What Command are you starting with? 18hp? 20hp? 22hp? More?
-Ryan
Old 03-31-2016, 08:46 PM
austin8214's Avatar
What part of Illinois are you in.
Old 04-01-2016, 09:35 AM
We have an 18 horse engine and believe it does not have much done to it. Bought it as is. Just want to stay competitive on a budget. Would love to do a 25 horse engine, but trying to save up for that. We are allowed 4250 rpm's, front flywheel, .030 over bore and the cam mentioned above. No other performance enhancing parts. I am located in Marshall.
Old 04-01-2016, 09:52 AM
Leadslingingdaddy's Avatar
You can gain about 4 easy hp modding the carb throttle stop or exchanging it out....Do a search on here there are a few topics on that same issue....
Old 04-01-2016, 02:56 PM
Thanks i'll look into this. Does anyone know the cam specs. on the 18hp the 27hp camshafts? I heard there may be a little bit of power with a 27hp cam also.
Old 04-01-2016, 04:25 PM
austin8214's Avatar
Not sure how far you are from Wyoming, Illinois but, there is a man there that can make it run. I would highly recommend him if you have the $$$ to spend. If you want his information send me a PM.
Old 04-01-2016, 05:53 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
they like allot of compression and timing
Old 04-04-2016, 09:13 PM
782CC 782CC is offline
Are you allowed to run a box that controls timing or is that a performance part?
Old 04-04-2016, 10:56 PM
The box is not allowed. Cannot run adjustable flywheels either. We can run velocity stacks. Is that any help at 4250 rpm's? I want to thank you all for the replies and we will check into all suggestions.
