Greg Rozar AKA- CubDieselFan
Old 06-17-2017, 05:24 PM
coinman66 coinman66 is offline
Default Hydro rebuild kit for 1720
Is there a hydro rebuild kit for a Cub Cadet 1720? If so, what is the part number? Is this a fairly easy job to tackle?
Thank you
Old 06-17-2017, 06:09 PM
Thank you
What is the problem? they are not the sundstrand unit, so other than a seal or 2, most just parts them out when the hydro goes bad.
Old 06-17-2017, 06:15 PM
Nothing wrong yet George, I just would like to do some preventative maintenance if possible. Is there a hydro filter on this particular model? Also trying to see if there is a full line marked on reservoir where u put hydro fluid. I noticed there is a rubber gasket type thingy inside u can pull out. Gonna have to download a service and operator manual.
Old 06-17-2017, 06:34 PM
ironman's Avatar
ironman ironman is online now
Thank you
I'm assuming you have a Hydro-Gear transmission. You gotta know the model number, it is on a white tag on the transmission.
You can go here
http://www.hydrogearpartstore.com/?g...odqtQF2A#Error
or here
http://www.arkansas-ope.com/HYDRO-GE...AIR_PARTS.html
to look up parts and kits.
Go here for Service and repair manual
http://www.hydro-gear.com/service-and-repair-manuals/
Is it an easy job to tackle, I don't thinks its a big deal, but then I did a lobotomy on myself with with a mirror and X-Acto knives.
All of the parts are expensive and tearing one apart just for routine maintenance is not something I would personally do.
Old 06-17-2017, 06:40 PM
You can go here
or here
Ok thanks Iron man. I thought i saw somewhere about a rebuild seal kit for like $20. Unless it starts leaking or something probably just leave it alone. Just change hydro fluid. Love the Kohler 17hp magnum in that sucker!
Old 06-17-2017, 06:45 PM
You can go here
or here
Now that explains a lot, Ha,LOL!
Old 06-17-2017, 06:57 PM
ironman's Avatar
As I said, I don't know what model transaxle you have. Most don't have drain plugs, if yours doesn't you must remove it from the tractor and drain it upside down through a vent. Fluid inside is 20W50 motor oil not hydro fluid. There is a filter inside but to change it you must open the case. Then of course you WILL need a seal kit too. Filter, about $35.00, seal kit about $20.00, oil $7.00 a quart (need 2), tube of sealant to seal the case $7.00. Shall I go on....?
Old 06-17-2017, 07:04 PM
ironman's Avatar
It was a lot easier the second time.
Old 06-17-2017, 07:05 PM
Sounds like if it ain't broke, leave it alone! Lol
I will get transaxle model number. So they don't take Hy Tran? 20w50. Got it. Thanks
Old 06-18-2017, 12:12 AM
That would be best. Or if you go diggin' you may begin to see leaks and trouble where you didn't before.
