Greg Rozar AKA- CubDieselFan
Old 02-04-2017, 11:36 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
Fantastic work Fred! Please keep the very informative descriptions and the pictures coming.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 02-06-2017, 04:39 PM
OldSkull's Avatar
OldSkull OldSkull is offline
Originally Posted by farmall fred View Post
I tried to tig weld the patch in the hood but just could not see well enough to weld the thin metal so I had to resort to the Mig. It got the job done but it took more grinding to get it finished.
Tom
Don't worry you did a hell of a job on that patch! You are not getting younger but your skill speak for yourself!
More "Yummy" pictures please!
Gilles.
1963 100 (red)/in storage
Old 02-07-2017, 10:41 AM
farmall fred's Avatar
farmall fred farmall fred is offline
Thanks for the complement. It is frustrating that I have the ability but just cannot see well enough to tig weld like I used to. About 30 years ago I chopped the top on my 40 Chevy Coupe and all joints were hammer welded using a torch and a hammer and dolly. Believe me when I say that if I could see better you would not even been able to see the seam where I welded the patch. Yesterday I finished getting all of the sheet metal prepped for two coats of epoxy primer. cleaned the shop floor and today I should get the parts sprayed. While waiting fgor the epoxy to cure I plan on removing the engine and stripping the frame to get it ready to paint. Still debating between a black chassis like the 88 series farm tractors or red like the 82 series Cubs. I like both.
Later
Tom
Old 02-07-2017, 08:14 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Good night you are going to have a show piece when you get done!!! It will be what cc shoulda done with the cyclops series
1- 1200 in pieces
1- 1864 in pieces
Old 02-07-2017, 10:59 PM
Thanks, that is my goal to build what should have been the Cyclops instead of the plastic fantastic. I still have not figured how to do the tilt wheel but I need to finish it and move on to my 57 Chevy project. I did get epoxy primer on all of the sheet metal today. I will post a couple of pictures tomorrow.
later
Tom
Old 02-08-2017, 01:13 PM
i love this build
Old 02-08-2017, 07:02 PM
Originally Posted by mjsoldcub View Post
i love this build
Me too. This guy seems to have the knowledge of ole George, the body work talents of Tim aka Olds, and the hydraulic knowledge of Trent. I like seeing multi talented guys on here.
Some proclaim how skilled they are and flash their credentials but have no real proof to back it up. It's cool to see it happening in threads like this and for me personally I'm always liking the explanations with details and learning new things along the way.
Right on Tom.
Old 02-08-2017, 07:55 PM
I look at threads like this and think I am not worthy. Some of you guys have talents that are flat out incredible. I'm happy when my stuff runs.
Old 02-08-2017, 10:30 PM
Guys, thanks for the complements. It means a lot to me coming from all of you.
I have always been a self taught do it your self type of guy. All of the work on my 57 is being done by me including the upholstery. I did have to farm out the machine work on the engine though.
I have all of sheet metal that will be painted red in epoxy primer and today I have the chassis mostly stripped to start preparing it for the black paint. Just a couple of progress pictures of bare metal and epoxied parts.
Later
Tom.
Bare metal awaiting final wipe down with wax and grease remover and Epoxy Primer
After two coats of Epoxy, I have to use a small amount of body filler on the hood and rear fender pan, most parts will only need a couple of coats of high build primer and block sanding to be ready for final paint.
Tomorrow I will finish tearing the frame down and start prepping it for paint.
Later
Tom
Old 02-09-2017, 12:00 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Right on Tom.
Mike,
I fully agree with your thoughts!!
Tom is very multi talented as alot of guys on here are!!
Jay
Proud owner of the following:
