#151
Looks factory fresh, gonna be a great Cub when you're through with it.
#152
Looks great!
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
#153
Engine Complete
Finished the engine assembly today. I know, I know...the muffler isn't stock. It will have to do until I can re-build an original I have.
Installing the anti-rattle clips on the PTO clutch was alot of fun...grrrrrr!
Cub Cadet 149 (Restoration Completed 2012) Cub Cadet 149 Cub Cadet 127 Front Blade 1A Tiller 38" Mower Deck 44" Mower Deck 48" Scraper Blade Plow spare 12 HP Kohler |
#154
Re-Installing the Engine
Drop the engine back in the frame today also. Everything went quite smooth.
http://www.onlycubcadets.net/forum/p...pictureid=2897
#155
One More Pic
#156
Excellent work on the motor!
Allen Proud owner of my Original! My Grandpa's Cart Craftsman Lawn Sweeper Craftsman Plug Aerator |
#157
#158
Hey guy I like your work.
#159
Thanks
Hey, thanks everyone - appreciate the nice words.
I wanted to mention that I had to use a tank sealer on the gas tank. Just to much rust inside for my taste. I used a couple of products that did a very nice job on the clean up and sealing. I'm probably about an hour away from start up. I'm missing a small piece that clamps my choke cable down - need to finish attaching the wiring harness to the engine. I'm using a diesel engine oil for break-in then I'll switch to synthetic. Hope I got my wiring all correct - need to jump those terminals on the voltage regulator also. Well, almost there...
#160
Throttle and Choke Linkage
Someone asked me how I remembered how to run the throttle and choke linkage after removing it so long ago.
Truth is, this 149 didn't have a carb when I rescued it. - fact is, half the linkage pieces were missing also! So, just how then did I know how to run the linkage? A manual? good answer, but no. The manual I have has pictures to dark to show the linkage hook up. Ok, so just how then did I know? Well, I did what any good cubber would do... I bought another 149 and took pictures of it! Thats my story and I'm sticking to it!
