Greg Rozar AKA- CubDieselFan
Old 05-13-2018, 06:12 PM
whaler12 whaler12 is offline
Do you have any pictures of that? How did it hold up? I got this blade for a decent price already had new hoses made etc. and any power angles Haban or not don’t really come around often so I think I’m going to see if I can get this to work.
Old 05-13-2018, 06:42 PM
I agree on that point but the 1872 is 200lbs heavier.
So is my 1811 with fluid filled tires and 75# wheel weights.
Actually it is 300# heavier.
Old 05-13-2018, 07:43 PM
Yes it is.
But if you did that to the 1872 it would be 300lbs heavier than yours, plus add a Fatty Arbuckle and your 1811 with your little man body will not compare.heheheheh
I would look for a Haban blade for that 1872.
Up to 530 and counting...
Old 05-13-2018, 07:58 PM
Steve N Mi Steve N Mi is offline
If you are directing your post to me ??? Then the pictures are in post# 6. It has worked very well for the past 3 years. I spread out a pile of dirt for planting last week just before pulling the blade off and installing a 50" deck for mowing.
Do you have access to a Haban blade near you that you can copy to fab up an undercarriage for your blade? If you can cut and weld, go for it.
Old 05-13-2018, 08:56 PM
.... plus add a Fatty Arbuckle and your 1811 with your little man body will not compare.heheheheh
Touche!
And that's why I have CaCl2 in the tires, lol.
Old 05-13-2018, 09:38 PM
TNTs CC TNTs CC is offline
Yes it is.
I'll raise you an 800# Cub 3240 with 70# cast wheel weights, filled tires, weight rack with five 42# suitcase weights, a full steel Sims cab and a 300# operator. Gotta add the 54" blade, hitch 2 hydro circuits weight to that too.
How does that compare??? That be about 1900# with the blade or about 2100# with the snow blower. It was probably too heavy if that's possible.
It's the best plow GT I've ever used and unstoppable with the snow blower too. Next year I'm gonna have one tractor set-up with a blade and another other with the cab and snow blower combo.
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights
GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder
3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller
1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers
Old 05-13-2018, 09:54 PM
800 tractor
140 w.w.
210 s.w
100 fluid (assuming not CaCl2)
300 operator
120 cab
25 misc weight
I get 1695 pounds.
Blade probably 95# 100# at most
Blower probably 150/160
Still not 1900# with the blower. I think your numbers are a bit off.
Old 05-13-2018, 10:27 PM
800 tractor
140 w.w.
210 s.w
300 operator
120 cab
25 misc weight
I get 1695 pounds.
The all Sims steel ext cab and doors is easily over 300#. the quick hitch and hydraulics are about 90# I'd guess the blade at 70#, the front tires are filled and the blower goes about 250# I believe, it's a tank. I probably go 320# in reality too.
Old 05-13-2018, 10:38 PM
I've got a steel cab. They aren't 300#. I can pick it up.
Blowers aren't 250. I want to see a stamped scale ticket. I've been around way too many tractors. An IH 284's weight is 2050 without ballast. It's way bigger than your set up.
Old 05-13-2018, 11:11 PM
The standard length 3000 series Sims cab is 294# with soft doors. Mine is longer, has 2 more windows and steel doors with glass.
Read the sales flyer pdf link in the link listed below.
https://www.cabdepot.com/documentati.../Sales%20Flyer
Here's a link about the 353 blower weight. It's over 200# easy.
http://www.mytractorforum.com/19-cub...ow-blower.html
According to post #10 it weighs more the a 47" JD blower.
Even a smaller lighter duty 42" stamped 2 stage Agri-Fab snow blower weighs over 200#....
