Lt1045 drive belt
I have a 7 year old Cub cadet. The drive belt is very worn and need to be changed out. I have watched some videos, and have determined that loosening the engine is the best way to deal with those 3 tabs surrounding the engine pulley.
The only problem is that I can only get to the 2 front engine bolts. The 2 rear bolts appear to be under a metal plate that has some steering linkage/gear on it. Any ideas on how to get to those 2 bolts? Thanks |
You do not have to remove the engine bolts. Remove the mower deck, Then lift the tractor from the front, I use a chain hoist, but a HD floor jack will work.
There is a bolt in the center of the pto, holding it to the engine, remove that bolt and the pto will come down. It may have a belt keeper that you will have to remove but no big deal, easily removed. PS you will need a impact wench to remove the pto bolt. Slip the old belt out and reinstall in reverse order. Here is a parts manual with the parts breakdown that might help. http://www.cubcadet.info/Manuels/200...1050-Parts.pdf
Larry |
Bamafan,
Should the pulley above the PTO come off as well? They’re are 3 tabs around that particular one that keeps the belt from coming off.... |
Did you look at the diagram I posted?
Larry |
OP, once you remove the PTO, the upper pulley should come down off the shaft. Just like ironman said. |
J-mach and Ironman are correct. Been awhile since I did one.
Larry |
Thx.
I will give it a try. My belt is hanging on by threads in some spots. |
Thx. Pulley slid right off after removing PTO...
How do you normally install the PTO. Can’t really torque it. Just use the same impact wrench? |
Yes
10 characters
Larry |
