Greg Rozar AKA- CubDieselFan
Old 03-31-2018, 11:13 PM
Originally Posted by gt383mag View Post
looks like the tank from my 782d is different than yours mine has the notches for the fender mounts but pokes out on each side. im guessing that a super three point isnt gonna fit looks like the rock shaft arms are gonna hit the tank
Yeah.... the 782D and the 1772 use different fuel tanks. One is a GT, the other an SGT. 782D, 882 and 1572 all use the same tank. So I guess the 1772 is the "odd duck".
Why were you planning to put a SGT rear hitch on a GT? You would have to notch the rear frame of the 782D for it to work, even if the arms didn't fit the tank. You can put a GT rear hitch on an SGT without mods, but not the other way around.
Old 04-01-2018, 01:13 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
All put together and ready to plow -till.The super tank has cut outs for the pto driveshaft and lift arms.
Old 04-04-2018, 01:51 PM
gt383mag's Avatar
gt383mag gt383mag is offline
Jon nope it is now a super used a cyclops iirc a 2082 frame my 782d tank has a 'tunnel" for the rear pto driveshaft to fit but im pretty sure the rockshaft arms will hit tank
Old 04-08-2018, 08:56 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
Looks like the same CV shaft I put in my turbo 1772. Mine lasted a few years. The shaft has a bend in it now. Vibrates pretty bad. Time to figure out a new shaft. CVs have held up well though. Hope you have better luck.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 04-09-2018, 11:23 AM
The loader puts a lot of stress on the frame twisting.I have a Case 644 the loader is built as part of the tractor not much flexing.
Old 05-24-2018, 05:45 PM
Finally got my grass eater together.The 1772 with the turbo should be easier on fuel,when mowing I run 3-4 Psi boost at center operating temp. Need to keep eye on temp if screen gets full of Cotton wood fuzz.
Old 05-25-2018, 10:42 AM
pictures for above
Old 05-25-2018, 11:59 AM
Terry C's Avatar
Terry C Terry C is offline
Sweet!!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 09-11-2018, 11:51 AM
Been mowing a lot with the 1772 I get 3-4 psi boost while mowing. Very quiet with the muffler on all you hear is the blades.
Old 09-11-2018, 06:16 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
as usual nice work Mike !
scan in the QR code (upper left) or text IHCC to 51660 to follow which shows and pulls we will be attending.
