CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 01-01-2017, 10:07 AM
I have never come even close to running out of power with a twin cylinder Briggs or Kohler engine and that includes the 14 Vanguard. I have run out of traction at the wheels.
Your requirements may be different.
Old 01-01-2017, 11:12 AM
Originally Posted by alltractoredup View Post
True.....well I am looking at repowering a couple tractors. The WG600 was put in grasshopper mowers too I have found out. Bssically, I want to repower my 1440. I know I would have to lengthen the frame with the kubota. With a CH I dont really have much work to drop it in. I have an opportunity yo buy a 2182 which I would keep original. I slso have a lead on a WG600 engine out of a Grasshopper......so.......I was wondering what guys thought of the WG600 performance compared to a Command as work horse tractors.
And I agree, the exhsust stack on th e 2182 is great looking
You DO NOT have to lengthen the frame to get the Kubota in. The hoods on ALL Cub Cadets are the same, even Supers.
In a 1440, I'd probably not go to the time and trouble of installing a Kubota. It's not really that easy unless you have a 2182 for parts.
Old 01-01-2017, 11:28 AM
Putting a WG600 in a 1440 is doable but not worth the cost or effort. You would need all of the special Cub mounts, battery support, radiator and you would need a custom drive shaft all NLA. You would need side panels from a 2182 or 1782 both NLA. Then without power steering the extra weight of the engine would make it harder to steer. Just my 2 cents, I'd look for a Vanguard out of a 2000 series Cub like a 2160.
If you go with a CH you'll need the exhaust system from something like an 1863, 1864, 2084 or 2284. You'll need a drive shaft from an 1863 or 1864.
Old 01-01-2017, 09:12 PM
alltractoredup alltractoredup is offline
Interesting.....a lot of good info I neede!! Thank you guys....I will stick with your advice and hold off on the repower. I dont really NEED the extra power, it just seemed like an interesting idea. I think buying the 2182 is more realistic from the advice given...thanks!!
Thread Tools
Display Modes
