Greg Rozar AKA- CubDieselFan
Old 07-21-2016, 03:55 PM
I'm impressed. The blades should work as long as you keep them out of the dirt and rocks. Dado blades are another possibility.
Old 07-21-2016, 05:26 PM
IHinIN IHinIN is offline
Thanks guys. I'll try to get video proof of it's success or failure. I plan on digging out around to stumps to clear away the dirt and possible rocks.
I did a little test cut on a 2x8 until it caught traction and the board moved.
Old 07-21-2016, 07:31 PM
We shall call it "the beaver".
Old 07-21-2016, 07:43 PM
Roto-beaver?
Old 07-28-2016, 09:51 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Looks cool!
1- 1200 in pieces
1- 1864 in pieces
Old 08-17-2016, 10:23 PM
V30crewcab V30crewcab is offline
when you wear those out, you should build something using an automotive flywheel and add the teeth, so it does't slow down as easily. that's how most stump grinders are.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 03-19-2017, 09:35 PM
Made a new cutter head with carbide inserts and mounted it between the bearings.
Old 04-03-2017, 08:03 AM
Looks like it should do the job.
Old 04-03-2017, 09:53 PM
Good job as always, Adam!
Proud owner of my Original!
