how to restore cast iron 1650 nose
I've worked with restoring metal parts. But am a bit new to cast iron. I want to start restoring my grill off my 1650 but wanted to know whats the best way of removing paint and repainting the cast iron grill?
Thanks, Nathan |
Grill shell
Nathan,
I just finished doing this. My goal was to save the rough as cast look so I just used stripper on it. Came out looking great. Good luck with yours Dave |
80 grit on a d.a use finishing putty to fix deap scratches or dings or small cracks. Then 180 gritt and prime. Couple good coats let dry 400grit the primer and reprime again then 400 grid and paint
882 diesel, 782ccc, 782ih, 102, 62 original, 108 x2, 124, x3 vtwin 82 seriers pullers, 1 wide frame puller project |
ok, thanks guys!
Wire wheel on a drill works great if you don't want chemicals but still want the rough cast look
1872 - 60"haban 54" power angle haban blade '63 Original - restoration project 582 -tiller 147 - leaf duty with bagger. 1811 - Ditch mower 800 - have it just cuz its a 800 |
