Greg Rozar AKA- CubDieselFan
Old 11-21-2017, 01:39 PM
If you're going to replace one pin you need to replace them all. If one broke the others probably aren't far behind.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-21-2017, 01:52 PM
I guess the load of pumping the PTO lift and the motor at the same time exceeded the (probably OEM) shear pin.
No.... not really. Sure the load wears on the pin......but really it's the hammering of the engine that beats them to death and breaks them. Diesels are worse. You need to keep them on hand. The guys who have 782D's break them all the time.
Old 11-21-2017, 02:11 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default All is good
I replaced it with a temporary expedient (cap screw with 1.25" long 1/4" shoulder, then #10 threads) and ordered the right Spirol pin.
Thanks all! A quick fix thanks to you.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 11-21-2017, 02:13 PM
jbrewer's Avatar
.....oh, and it was a Spirol pin. I ordered 3 of them and will get them in this weekend when they arrive.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 11-21-2017, 02:14 PM
That made no sense. 1/4" bolts don't have #10 threads.
So, you put a bolt in it.... that will hold it for a while. McMaster Carr has the pins. Good price too.
Old 11-21-2017, 02:37 PM
john hall's Avatar
Probably a shoulder bolt--those are designated by shoulder dia, not thread size.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-21-2017, 03:03 PM
Terry C's Avatar
Terry C Terry C is offline
From my tool and die days stripper bolts
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-21-2017, 04:22 PM
jbrewer's Avatar
No, it's an allen head fastener that has a smooth steel shank 1/4" in diameter by 1.25" long, then 1/4" of #10 or #12 threads. It fit perfectly, but as soon as I get the Spirols, I'll replace it with the right part.
I didn't want to use a bolt as I didn't want the threads eating away at the trunions while the Spirols come, and Ace Hardware had em. Shoulder bolt sounds right. It's really amazing the Spirols have enough shear strength to pull the tractor yet yield when they need to.
I ordered the fan while I was at it too. Cool is good.
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 11-21-2017, 04:28 PM
cubs-n-bxrs's Avatar
#10 or#12 are bolt sizes. !/4in bolt is either 20 tpi or 28 tpi.
Old 11-21-2017, 04:32 PM
jbrewer's Avatar
Whew.....
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Thread Tools
Display Modes
