LT1050 PTO problem
Hello all, first timer here! Any how, I recently have been having some problems with my tractor. The pto disengages after a few seconds of running. If I put it into reverse mode all is fine and I can cut for hours. It's just when it is in normal
Mode. Any ideas? Only work I've done to it in the pst month was replace a head gasket and I recently modded a peco bagger intended for a zero turn to fit my tractor. |
I would look at the Reverse Switch first. It would be located in the Hydro Lever area, in that the lever has to engage/disengage the switch. I am guessing that this switch is "sticking".
Awesome thank you, I'll investigate later today. When you say hydro lever are you referring to the hydrostatic transmission foot pedal?
Yes.........
