Greg Rozar AKA- CubDieselFan
Old 07-01-2017, 07:53 PM
daniel2229 daniel2229 is offline
Default LXT 1045 mower height
I have had issues with the mower deck height from day-one. If my tires go down just 2 or 3 pounds, the mower deck seems to scalp the grass. I mow at the highest level and the deck adjustment screw under the muffler is all the up.
I also have the mower deck dolly wheels set at the lowest point so the deck will ride the highest.
It seems I have done all I can do.
Any suggestions? Is there another adjustment somewhere else on the mower deck?
Thanks,
Daniel
Old 07-01-2017, 10:26 PM
Bamafan's Avatar
Bamafan Bamafan is offline
I would keep the correct amount of air in the tires. Look on the tire it will give you the amount to inflate them. Under inflated tires will effect the cutting of the mower deck.
Larry
Old 07-02-2017, 07:01 AM
john hall's Avatar
If your tires are leaking that bad, put tubes in them. We're running some tires that are 30+ years old and they never need air added. Personally, when I run into a non-automotive tubeless tire that leaks, I put in a tube.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 07-03-2017, 02:54 PM
Yep, definitely need to keep a watch on the tires; however, even with the tires pumped up all the way, I still think the deck is too low.
I'm looking for a mechanical way of lifting the deck.
Daniel
Old 07-03-2017, 05:02 PM
Maybe you just have unreal expectations for the height.
Grass should be cut no higher 2" or maybe 3" in my opinion.
Old 07-04-2017, 04:42 PM
TIMCRUTCHER TIMCRUTCHER is offline
I'm at 1-3/8 working down to 1".
I don't use my Cub. I just work on it and look at it. So far it's holding up very well.
Old 07-04-2017, 05:40 PM
I do 3-1/2" or I hit rocks at my place.
Old 07-04-2017, 10:17 PM
Ugh. I can understand a higher cut for that.
I do not envy you my friend.
Old 07-04-2017, 10:18 PM
You shush. I know what you're mowing.
Your grass looks good really short.
Thread Tools
Display Modes
