Greg Rozar AKA- CubDieselFan
Old 06-27-2017, 08:09 AM
pabble pabble is offline
Default GT1554 keeps throwing deck belt...can you help?
I recently bought a GT1554 with 54" deck that appears well cared for but it keeps throwing deck belts. the previous owner said it happened sometimes but not constantly as it has done with me. I've only been trying it on very dry grass about 3" long on a relatively flat ground so shouldn't be any undue strain.
I dropped the deck and when I put a level across the pulleys they are level with the exception of the one turning the left blade, nearest the idler pulley - that one sits about 3/8" lower than all the other pulleys. Is that how it should be? it seems a lower pulley would increase the angle when the deck is lowered for mowing (I set it at 3) and only encourage the belt to come off. I put a new belt on but that didn't solve the problem. the tension spring on the idler appears in good condition but the mower is new to me so don't know if it provides the tension needed.
so my first question is....are the deck pulleys supposed to be level on a 54" deck or is the left blade pulley designed to be lower? previous owner said he had not changed the pulleys but he is the second owner so not sure before that time. Any help or suggestions would be greatly appreciated.
Old 06-27-2017, 09:36 AM
First, welcome to OCC....
Since you have posted no pictures, I can only respond with General Statements.
Usually when belts are being thrown, it falls into one of two areas.
(A) The wrong belt is being used.
(B) There is a mis-alignment of the Pulleys, and/or Idlers.
Roland Bedell
Buy: Made in the USA
Old 06-27-2017, 11:14 AM
V30crewcab V30crewcab is offline
do the blades line up underneath? that would rule out bent deck. may just have a pulley on upside down or something got put together wrong in the bearing assembly.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 06-27-2017, 11:27 AM
A pulley on upside down....... ???
Old 06-27-2017, 11:29 AM
The blades should be in the same geometric plane to afford level cutting.
Roland Bedell
Old 06-27-2017, 05:32 PM
ironman's Avatar
ironman ironman is online now
Just to clarify, you do mean the deck belt and not the pto belt, right?
Anyway, For what its worth, this is a picture I have of the 54" deck on a tractor I just sold. While I had it, no belts were ever thrown off. I know the outer spindle pulleys are covered in the picture but I just can't imagine them not all being on the same plane. Are you sure you have the right belt and that it is installed like mine.
