Greg Rozar AKA- CubDieselFan
Old 11-16-2017, 10:48 AM
Masmith Masmith is offline
Default New shop toy.
This should make working on the 108 a little easier. Extensions on the Hydraulic motorcycle lift.
File Type: jpg 53248140104__57F4FC12-BBE5-4FE2-81A5-00252907C773.jpg (23.9 KB, 237 views)
Old 11-16-2017, 11:05 AM
Jumper Jumper is offline
My back feels better just looking at that lift ! Nice addition to the shop
Old 11-16-2017, 11:32 AM
Terry C's Avatar
Terry C Terry C is offline
Nice!!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-16-2017, 12:07 PM
yettrbomb yettrbomb is offline
Nice! More pics!
Old 11-16-2017, 04:24 PM
Merk Merk is offline
I'm looking at one of those for my shop.
How tall is the lift when it is all the way down?
How high does it go?
electric or air powered?
Project Uncle Dick
Cub Cadet 70
Old 11-17-2017, 08:33 AM
willys55's Avatar
willys55 willys55 is offline
adding that to my wish list
64 Cub Cadet 100
Also have quite a few Non Cub Cadets in the Shed
Old 11-17-2017, 10:19 AM
Nice lift! Can we get some pics of how you made the extensions?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-17-2017, 11:18 AM
Dirty Steve's Avatar
Any stability issues??
Old 11-17-2017, 05:23 PM
When it's down it is about 6" above the floor. Maximum height is 32". It is a hydraulic pump which hooks up to the air line. It has different locking heights so there are different positions up to the 32" height. There are no stability issues at all. You can also put longer pieces of metal through the metal on the floor to increase stability if needed. It is made by Direct Lifts. I've had it for a while using it for my Harley. The extensions are secured by 3 1" rods 50" long (heavy wall conduit)that slide through the lift. The extension kit cost $230 so I used the aluminum walk boards I already had and used a knock cutter to put the holes in them.
The walk boards were originally one 16' piece and someone cut it in have to make ramps. I would never have done that, but since they were already cut they worked out great.
Old 11-17-2017, 08:01 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
You must be an electrician
1- 1200 in pieces
1- 1864 in pieces
