Greg Rozar AKA- CubDieselFan
Old 01-31-2016, 05:36 PM
Ok now you're just showing off.
Nice job.
Old 02-01-2016, 12:13 AM
Originally Posted by Nightow1 View Post
Not to sound to braggy, but kinda nice to be able to use a rear bucket and a front blade independently. Not many cubs out there that can do that.
Heck, if I has the equipment and know-how you boys got, I'd be thumpin' my chest... Ain't braggy, just the facts.
Old 01-30-2018, 09:22 AM
sawdustdad's Avatar
Do you happen to know the retracted length and stroke of the cylinder you used on the power angle blade? Or even a link to it?
Have a dual spool valve I want to put on one of my QLs, and a 54 inch blade.
Old 01-30-2018, 09:55 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
That cylinder is a 6" stroke which is perfect for a 42" blade. It's one I bought for an experimental project that turned out to be a perfect fit. I'll include links below, I'm sure Nightow1 woulda responded but he was busy fighting fire today!
42" blade cylinder
http://www.surpluscenter.com/Brands/...e-9-7706-6.axd
54" blade
http://www.surpluscenter.com/Hydraul...-9-4410-08.axd
54" blade, cheaper option with a larger-diameter rod. Rod needs to be cut with a pin hole drilled in it to get closer to the retracted length measurement.
https://www.amazon.com/gp/aw/d/B00BG...P2WWJN2L&psc=1
1- 1200 in pieces
1- 1864 in pieces
Old 01-30-2018, 11:32 PM
sawdustdad's Avatar
Thank you, Rescue11, for the quick response! Just what I needed.
Old 02-01-2018, 08:06 AM
Dirty Steve's Avatar
You guys rock the hydraulic work. Awesome!
Old 02-01-2018, 02:34 PM
Rescue11's Avatar
Your welcome Sawdustdad!
This looks like a cheaper option for the 42" blade. Only 7/8" longer than the Surplus Center one on collapsed length. I'd buy it.
https://www.amazon.com/Welded-Cylind...H4W4R3E8JYV6YC
Bought the one from Surplus center before I even knew that they sold these
Thanks Steve!!
1- 1200 in pieces
1- 1864 in pieces
Old 02-01-2018, 08:03 PM
That is very true. Nice build up.
Roland Bedell
Buy: Made in the USA
Old 01-16-2019, 08:25 AM
Mike33 Mike33 is offline
42" blade cylinder
54" blade
Good Morning,
I wanted to confirm that the 54" blade cylinder from surplus center is a direct mount and go option for the Haban blade beside the mounting bolts and lines etc? Is there any additional work needed to be done or is this a near identical cylinder that comes in the cub cadet kit?
Thanks in advance.
Old 01-16-2019, 07:13 PM
sawdustdad's Avatar
I used the cylinder recommended by Rescue11 on a 54 inch blade in this thread:
https://www.onlycubcadets.net/forum/...ht=power+angle
