2" - 4,000 rpm, 1 cylinder tach
If anyone is interested in a 2" tach check out this link. Lots of other good stuff too. Chris
http://www.steam-brite.com/veethree-...nt-p-7584.html
1968 104 , service replacement '96 K301, 42" deck 1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck 2007 LA130,21hp Intek v-twin, 48" deck As you slide down the banister of Life, may the splinters point in the right direction . |
Cool, and affordable too.
Good find! Just wonder how precise it is compare to a optical speed sensor one
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
These tachs are digital frequency counters.
Unless the programing or logic is bad there are only two sources for error. The first is the time base used to know when a minute is up. If the time base drifts 2% so does the RPM reading. A better unit would use an external 50 cent crystal. A really good one would control the crystal temperature. I expect these use a clock internal to the chip which is less accurate and changes as the chip heats up with use. The 2nd source of error is in sensing. A optical setup with good contrast will be quite good. To know how well a wire wrapped on a plug wire will work look at that signal with a scope. A single cylinder does not have a distributor which is one less source of noise. A good plug wire should help. Less electrical noise is good. |
According to this: http://veethree.com/veethree_catalogue.pdf
That gauge is on page 13, and is #2. I picks up off the ignition coil, so it's not inductive. PLUS, it is for a minimum of 2 pulse per revolution. So, it won't work with the single cylinder K series. I will work on the KT's and the 3cyl Kubotas. This has been the biggest problem I've found with these little tach's is they are for wasted spark single cylinders. It doesn't appear to work with magneto ignition either so it won't work with the Mag18 or CH's. Sorry guys. However, if you are smart enough, you could make it read off of the alternator on the Mag motors. |
So does anyone know of a 2'' tach that will work on our 1 cylinder Kohlers?
Perhaps the puller boys know of one..... |
i am sure they are out there but at a price too.
Seems like there would be. But I have 10 different catalogs and probably 20 vendors I can call that carry that sort of thing. Plus a million internet searches and checked every gauge manufacturer that I know of. Nothing. There are many that are for the wasted spark, or 2 sparks per revolution.... none for singe. I do think that there are a few digital ones. But not analog (needle) gauges.
I contacted David Kirk a few months ago . He said he had to contract for 100 tachs at a time ,also took too long to sell them. If there was enough interest he would offer them again. Does anyone remember when he sold them and if they were for 1 cylinder engines only?
Chris
