Greg Rozar AKA- CubDieselFan
Old 10-21-2017, 10:12 PM
fieldman12 fieldman12 is offline
Default 1650 Cork gasket leaking Part II
Well got the hydro removed from the rear today. I must say it went very smooth. I took everyones advice and removed the rear from the tractor. It took me about six hours. If I would have had all the tools, jacks, and blocks out it would have went much quicker. I cleaned both surfaces real good before bolting the hydro and rear end together. I noticed on the top half of the mating surface where the gasket sits I had some aluminum discoloration. Nothing was pitted or anything but it was clear something changed the color. I got to thinking about what caused this and the only thing I could come up with is the battery sits real close to that location and I wonder if some acid had worked its way down to the gasket at some point. The gasket was lets just say falling to pieces. I know other models have this issue also but there battery sits in the engine area. I just cant help but wonder if this causes issues in the rear of the Quite Lines. I think im going to find something to put the battery in to keep the acid contained if it ever leaks again under the seat. I got to run the tractor around a little bit until the tie rod fell off and both front wheels when a different direction lol.
Old 10-21-2017, 11:43 PM
I wouldn't sweat it. Seems if I remember, a couple of mine were stained as well...
If your battery starts oozing it's contents, it would be time to replace it anyway.
Old 10-22-2017, 07:52 AM
mrfred54 mrfred54 is offline
the cork gasket gets cracked on all most every unit as it ages. I like to put aviation permatex on the gasket when I reassemble and make sure to torque the hydro mounting bolts to the diff. I like to leave the unit out of the tractor for a couple days to retorque the bolts before I install it in the tractor, just to make sure that cork gasket gets compressed good.
Old 10-22-2017, 08:25 AM
Your cork gasket was 35 years old, give/take.
The cork has reached it's life expectancy, deal with it.
Because I like to do things my way, I used a neoprene ho'maid gasket, and installed it dry, on one of my 782's.
So far no problems, but it is only about 10 years and 900+ hours.
I doubt in another 35 years I'll be around, although I'd like to achieve a 100+and die in bed----------
--------with a satisfied 30 year old nymphomaniac.
Now about about those 72 Virgins in the next life,
Who came up with that number anyway?
Old 10-22-2017, 08:38 AM
john hall's Avatar
One of my hydros had evidence of battery corrosion on the rear, although not specifically around the pump. Don't worry about it--just clean it up, spray a little paint to stop the rust and put it back together and mow on! Like has been said, the pump gasket is just one of those things that is going to fail once it is10-30 years old. Ask any long standing dealer and they will tell you that its an expensive repair with amount 90% of the cost in labor.
Glad you got it fixed!
If you try to come up with something to sit the battery in, make sure you don't raise it too high and cause the terminals to get into the seat.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Well, o'George...if you are going to dream...dream BIG! Good luck with the nympho!
Queen Of The Quietlines!
Old 10-22-2017, 01:16 PM
Well,-----
My wife said to me one time, if I ever went to bed with a young woman like that,
I would never live to tell about it!
------So I thought I'd let her be right just once
Old 10-22-2017, 08:32 PM
johncub7172's Avatar
I have some paint damage in my Quiet Line, but nothing serious. I just done what John suggested. Most of the time, I guess it's an old battery left in the tractor and freezes then cracks during a winter. I placed a cut piece of roofing shingle in all my tractors.
Thread Tools
Display Modes
