782 electrical help.
I'm working on this CCC made 782 and I'm having a bit of an issue. The PTO won't engage with the switch but it will if I jump the wires together at the plug on the switch. When the switch is off it has continuity between terminals F and B and when the switch is on it has continuity between A and B. I have two switches here that test out the same which leads me to believe the switch is fine. As I sit here looking at the wiring diagram it almost has to be something to do with the reverse cutout. Any other ideas I should check out?
Seat switch or reverse cut-out, if it has either.
First let me be clear, I don't advocate by-passing any safety switch on a permanent basis, but ---- You can jump (bypass) each one, one at a time, to see the results and decide if that particular switch is functioning. If you find a bad one, you'll know what to replace. Easy.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
That's what i was thinking, the seat switch is already bypassed so i will check on the reverse cutout later.
Tim, do you have the correct switch?
On a CCC 782 you should have continuity on the C & D terminals (red wires) in the "off" position PTO start -- continuity between B-A-F (black-brown-orange) PTO on -- B & A (black & brown) They didn't use the reverse relay on the IH built 782's. Do you need the schematic?
Tim, I just looked at your other post and with a 712xxx you don't have the reverse relay and the above wiring in my post is not the same.
Continuity as follows On = B(tan)-A(tan/black) Off = B(tan)-E(violet) & C(red)-D(orange/black)
Good call, I guess this tractor would have the IH wiring.
Do you have a wiring diagram for your use?
Ok, problem solved. Turns out i'm an idiot and didn't check the fuse, both the fuse and the cap were missing so i stole one from a parts tractor and now it works.
That is good to know you are what you say has happened and all is well.
