Greg Rozar AKA- CubDieselFan
Old 09-30-2017, 03:41 AM
jah457's Avatar
jah457 jah457 is offline
Angry 1572 Driveshaft is pretty much shot
I tore the driveshaft out of the 1572 Diesel yesterday and everything needs to be replaced. Both couplers that hold the ball bushings were really bad (one actually had a chunk out of it), the Disconnect Clutch looks like it exploded sometime in the past, and the driveshaft itself has deep burrs. I will post some pictures later today. I am going to a CV style driveline from a 1864 instead, and removing the Disconnect Clutch completely.
_________________
Godspeed,
107, 109 (2), 125, 129, 147 (pieces), 149, 1650, 1650 w/ Johnson FEL, and 1572 Diesel, 1958 Farmall Cub
Old 09-30-2017, 10:08 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Those Diesels seem to be pretty hard on the driveline... sounds like you are doing it right! Keep us posted.. you probably already know but we like pictures!!
Jay
Proud owner of the following:
Old 10-01-2017, 05:39 AM
jah457's Avatar
Default Pics of the worm 1572 Driveline
Jay, here's some pics of the damaged 1572 Driveline. I am putting in a CV driveline from an 1864 along with Jeff in PA's couplers. I was hoping to keep the Disconnect Clutch as it gets pretty cold up here, but it was too worn to re-use. Fortunately the splines on the Hydro Pump shaft are OK. I've also ordered the Rear End Braces from Xtreme Motorworks.
_________________
Godspeed,
Old 10-01-2017, 10:39 AM
jaynjeep's Avatar
THANKS FOR THE PICS!!
WOW all that stuff was pretty beat up! The CV driveline will serve you well.. Thankfully we have people like Jeff to make nice custom parts!
If you don't already have one put the modern gear reduction starter on it and with good glow plugs if should start even in the coldest weather without the disconnect clutch
Jay
Old 10-01-2017, 12:51 PM
jah457's Avatar
I’ve already put new glo-plugs. It has a newer starter on it, but I don’t know if it was OEM or another.ill try to read a model number for the starter.
_________________
Godspeed,
Old 10-01-2017, 03:04 PM
jaynjeep's Avatar
Here is the info on the gear reduction starter upgrade.. There are more threads about it on here but this is the first one I found. It will spin the engine easier and faster.. draws less current than the factory style starter also.. That leaves more juice for the glow plugs.
http://onlycubcadets.net/forum/showthread.php?t=1
I know there is a way to rewire the glow plugs so they get full voltage.. Apparently the way Cub Cadet wired them was marginal.. There are several threads on here about that also..
I haven't done either mod on my 1782 but it cranks easily and it rarely gets below freezing here. Plus all I do is mow with that tractor so it is pretty much parked in the winter months!
Jay
Old 10-01-2017, 06:30 PM
jah457's Avatar
Thx again Jay, much appreciated
_________________
Godspeed,
Old 10-02-2017, 06:01 PM
jah457's Avatar
Got the rear axle brackets from Aaron at Xtreme Today , found a used 1864 CV Driveshaft, and now to get the Couplers from Jeff. Coming together day by day.
_________________
Godspeed,
Old 10-14-2017, 04:16 AM
jah457's Avatar
Got the front and rear couplers from Jeff, picking up my 1864 CV driveline, replaced rear axle seals and the 'cork', replaced the Trunion Springs, buttoned back up. Here are 2 pics of the broken aluminium Hydro case front mounts.
Have to wait to next weekend for re-assembly with the Xtreme Motosports rear axle brackets. Getting closer one weekend at a time :-)
_________________
Godspeed,
Old 10-20-2017, 05:21 AM
jah457's Avatar
I'll have to wait another week to get the CV Driveline rubber boots being shipped from the USA, only one here in Canada and I need two. I guess today I'll do a dry mockup of the 1863 CV driveline with JeffinPA's couplers. I can also fit and mount the rear axle brackets from Aaron at Extreme Motorsports. Looking forward to some garage time after a stressful work week. Pictures to follow of course :-)
_________________
Godspeed,
Tags
1572
