anyone have one of the xtreme motorworks receiver hitches
I am thinking about making one myself. It would be nice to have as I could make a lot of accessories to hook onto it. Shouldn't be too hard as I have the stock hitch to make a template of the bottom holes with and then just measure for the upper holes. I believe I have scrap steel that would work for the back plate and id only be out the $6.99 for the reciever tube part and some welding wire.
Cub 104 Refurbed Sprinig of 2013 Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs |
It's not the steel one but a home made one that works I'm sure just as good not as pretty. It uses the stock draw bar as a bottom this is on my 123
1872 - 60"haban 54" power angle haban blade '63 Original - restoration project 582 -tiller 147 - leaf duty with bagger. 1811 - Ditch mower 800 - have it just cuz its a 800 |
throw some paint on that and it be just as nice IMO. Did you weld it to the stock drawbar?
I didn't make it but yes it is welded
We always bolted a ball onto the stock hitch.........................
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
I used to just put a ball on as well but started to get to he a hassle between the different things I pull always taking off and putting on the ball. Now I just slide the hitch in with the piece I need and I'm good to go. Also I can flip a drop hitch upside down and have the car trailer sit level its also how I plan to make my salt spreader/gras seed spreader attach to the rear and I'm sure ill make more.stuff as I go.along
I made one to go my sleeve hitch
Id like to be able to throw one of these on the back and toss a sack of concrete on it for extra plowing weight in the winter
Wheel weights are much easier on the bearings and axles. That way you have rolling weight exactly where you want it with no added strain on the drivetrain.
I plan to fluid fill my tires when I get to that point during my refresh on the tractor. Wheel weights are pricey and seem to be tough to come by. This would only be on there if needed for that. Otherwise there would be no weight. but I see your point.
