Greg Rozar AKA- CubDieselFan
Old 03-26-2018, 11:42 AM
Vrobert's Avatar
Vrobert Vrobert is offline
Default Dust cyclone
I have been working on a sandblasting cabinet and a 60 gallon compressor to do some restoration blasting. The cabinet needs a vacuum attached to collect the blasted debris which keeps the media cleaner and improves visibility while blasting. A friend has a similar blasting setup and he purchased a Dust Deputy to keep his shop vac filter from clogging. The Dust deputy works great but it's about $60 and its big and top heavy when mounted on a 5 gallon bucket. I decided to buy a Chinese cast aluminum copy that mounts inside a 1 or 5 gallon bucket rather than on top. It fits the smaller 1 1/8" vacuum hose (sort of). The tubes on the cyclone are 1" OD but I had a few extra hose extension pieces that I cut up and attached to it.
Preliminary review is good. I blasted a small rusty bracket and the bucket collected a handful of fine rusty dust. These aluminum cyclones are only about 7" tall and cost around $22 on ebay. Compare my one gallon setup to the 5 gallon Dust Deputy. For woodworking the larger setup would be necessary because sawdust would fill that bucket pretty quick but sandblasting a few small items each week wont generate that much volume.
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 03-26-2018, 11:50 AM
I purchased the dust deputy,,, and, I am SHOCKED how much vacuum is lost due to it.
Yes, it removes the dust, but, about half the suction power is used removing the dirt.
For specific things, sanding, etc,, it is great.
sweeping the dirty shop takes forever, because of the lost vacuum.
The vacuum is not lost due to leaks,, the vacuum simply has half the velocity at the pickup point.
Part of the problem is all the extra hose,,,
Old 03-26-2018, 12:00 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Looks like a small turbo housing?
Old 03-26-2018, 12:29 PM
You would be surprised at how much quicker a rusted part will clean up in your blaster if you soak it in vinegar for a day or so.
Try it!
Old 03-26-2018, 09:18 PM
john hall's Avatar
You SWEEP your shop floor??? I thought that's what leaf blowers are for.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 03-26-2018, 10:39 PM
I had the vortex, I had to try it out,,,
THEN out came the Stihl BR600,,,,
