CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 12-01-2017, 10:25 AM
David Reinhardt David Reinhardt is offline
Default CC 1641 Return spring location
I recently purchased a cub cadet 1641 (model number 144-653-100 serial number 854682).It is going to be winter project. I was able to get it running. The brake/clutch pedal was hard to move and wouldn't return to the up position. Brake shaft bushings were frozen cleaned them up and it works well. Now after all of that my question is ,the brake return spring is missing,#11 below, it appears to hook on a pin that goes thru part 10 below. It's the other end location that is giving me a problem. I have checked the service manual ,parts list,but just haven't found the connection point. Where does it go? Thanks Dave
The image below was copied from PartsTree.
Old 12-01-2017, 06:36 PM
brudder brudder is offline
This is the left side of the tractor if you were sitting on it. You will see three bolt heads in this picture. Yours probably has four, but I have my wiring harness out right now so the fourth bolt above the bolt on the left is take out. The return spring attaches to the middle bolt. It's not fun to put on.
Old 12-01-2017, 09:49 PM
Thank you . That helps a lot . It does look like it will be a chore. Thanks again Dave.
Old 12-02-2017, 09:36 AM
RumbleFish RumbleFish is offline
Agreed! I got educated on this when I installed my GT braces from XMW.
Old 12-02-2017, 11:20 AM
Yep that spring is a PITA. I use some safety wire to pull it from the back.
Old 12-02-2017, 01:40 PM
Thanks for the hint Sam Mac. Going to try it this afternoon. That's a pretty stout spring.
Old 12-02-2017, 03:52 PM
It went well . Thanks to all now it is on to the wiring harness it is a mess. I'll start a new thread and post some images of mods that were made they are neat �� .
Old 12-02-2017, 04:41 PM
Take a piece of 1/4" round and make/bend a hook on one end and a handle of sorts on the other end.
Be safe, Ya don't want that spring to escape on you once it is stretched out.
Thread Tools
Display Modes
