CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 12-02-2017, 08:33 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Originally Posted by CUBRAT View Post
I will do this when my rubber mounts arrive. Thanks!
That won't tell you whether that was the issue when solid mounted...
I'd pull the driveline, and fire her up. If it still shakes that bad, then you have an issue with the motor. Solid mounted or not, the motor should not have that much vibration. Eliminating it with rubber mounts will simply mask it.
Also, you haven't said whether you put in a solid driver. If you did, it is my understanding that running one with ISO mounts is a bad idea.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 12-02-2017, 08:41 PM
I currently have about 20 ball and worn shaft jokes and I'm really not sure which one to go with...
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-02-2017, 09:18 PM
DieselDoctor's Avatar
Never found anything tight enough to wear the shaft and if things don't get too violent, the balls don't get hurt either.
Old 12-02-2017, 09:23 PM
Originally Posted by dieseldoctor View Post
never found anything tight enough to wear the shaft and if things don't get too violent, the balls don't get hurt either.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-03-2017, 04:59 PM
twoton twoton is offline
Originally Posted by DeltaCub View Post
That is some big time wear! Should not have that recessed place on the end.
I make my replacement driveshaft FLAT on the ends.
Thanks people for confirming that. I was wondering.
Old 12-04-2017, 06:14 PM
CUBRAT CUBRAT is offline
Originally Posted by ironman View Post
He hasn't answered my question whether he used a solid 3-pin drive plate or a flex 3-pin drive plate. With a solid driver the drive shaft slides directly into the bushing in the center of the drive plate and you don't need no gosh dang balls.
Sorry for the late reply, had a busy weekend.
I am using a solid 3 Pin Driver from Zach Kerber. So you are saying the ball IS NOT NEEDED if running a solid three pin?
If that is the case, I can take the ball out and a 1/8" longer drive shaft should not have an effect as there is quite there would be quite a bit of room in the coupling.
Old 12-07-2017, 06:33 AM
CUBRAT, you need to keep the 5/8" centering ball inside the transmission input yoke regardless of what type of 3 pin driver you are using.
Old 12-07-2017, 11:59 PM
A solid mount do over is coming up. Solid mounts, cradle mod, Kerber solid 3 pin driver, resurfaced pressure plates, new roll pins, new teaser spring, new cup, new release arm, throwout bearing is good and will solid mount the rear coupler using 3/8" nuts.
If this doesnt satisfy me, I will go with Iso mounts and flex coupler.
Old 12-08-2017, 12:28 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
You may have a clearance issue with your cradle mod....especially if you use ISO mounts. You welded the cross strap on the undersides of the engine cradle. It may clear the chassis with solid mounts but may cause issues with the ISO mounts.
Queen Of The Quietlines!
Old 12-08-2017, 10:11 AM
Ugh!! Your right. Ill address that today.
Thread Tools
Display Modes
