Greg Rozar AKA- CubDieselFan
Old 12-04-2017, 12:13 PM
89cubcadet1772's Avatar
89cubcadet1772 89cubcadet1772 is offline
Just a FYI when I had Machtech do my valves they replaced just about everything that is inside along with all new seals. They sent the old parts back along with the repaired valves.
Yeah I seen that on the website, the pintle does not get changed, the ball bearing had no wear and the springs were springy-not sure what the height spec is on them... I air checked before/after welding and internals moved/seated correctly.
89' Cub Cadet 1772
Old 12-04-2017, 02:53 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Very nice work! Take a bow....
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-04-2017, 04:58 PM
Keep us posted on how they work. Just thinking out loud maybe you can be the rebuild guy in CA
Old 12-04-2017, 05:26 PM
Will do, need a good snow storm to put it to work.
Not sure I want that title lol, I still have the other one I replaced couple years ago as well, going to seal it up as well for a spare.
89' Cub Cadet 1772
Old 12-05-2017, 02:20 PM
farmall fred's Avatar
farmall fred farmall fred is offline
Thanks for posting this. I have a metal lathe so I will be trying this sometime this winter. I have a couple of valves in a spare hydro that were leaking so what better way to go. As far as the balls in them, any good bearing house can supply them if needed.
Tom
Old 12-05-2017, 02:49 PM
Tom
Thanks for the positive input. Was a lot easier then I imagined. Just sourced the o-rings at local hydro supply shop. The bearing was flawless. I figured minus the leak past the seal in valve, the tractor operated correctly so that's why I went this route.
89' Cub Cadet 1772
Old 12-08-2017, 08:46 PM
Bamma Bamma is offline
Default Repair
I did mine and it was very easy. If you google Todd Christianson relief valve repair he has it step by step
Old 12-08-2017, 10:20 PM
Default Relief valve
I’m sorry google hydro relief valve repair by Mike Christiansen
