Greg Rozar AKA- CubDieselFan
Old 11-18-2017, 05:43 PM
Big-D Big-D is offline
Default 1772 pump and rear end
I yanked the pump and rearend out today to change a leaking lip seal on the pump. Anything else I should be doing while it's all out?
Old 11-18-2017, 06:03 PM
Cork gasket between the pump and rear end probably wouldn't hurt.
Old 11-18-2017, 06:06 PM
I was thinking that. Anyone know the part number for that?
Old 11-18-2017, 06:22 PM
http://www.cubcadet.com/equipment/cu...vice-and-parts
Look it up.
Old 11-18-2017, 07:45 PM
These should be all of the seals and gaskets
Hydro Pump seals
SU-9008000-6701 seal 2
SU-9008000-7505 seal 1
SU-9008000-6201 seal 1
SU-3102875 gasket 1
SU-9004100-0360 o-ring 1
_______________________________
Transaxle seals and gaskets
921-3004 gasket 1 cork gasket
721-3014 gasket 2 carrier gaskets
721-0187 seal 2 axle seals
921-3015 gasket 1 rear cover
I just happened to have the list from a rebuild I did a couple years ago. You should double check using the link that J-Mech posted
Old 11-18-2017, 08:19 PM
I'd also do a set or rear braces while you have it drained.
http://www.xtrememotorworks.com/Part...Cub-Cadet.html
Old 11-18-2017, 08:34 PM
john hall's Avatar
Trunion springs and buttons while you can get to them.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-19-2017, 08:41 AM
IliketheRedcubs's Avatar
Don’t mean to be a “thread stealer” but where does one get these?
Old 11-19-2017, 08:57 AM
CubDieselFan's Avatar
Loctite sells them.
Old 11-19-2017, 07:09 PM
john hall's Avatar
Cub Cadet dealer of your choice. Myself, I use IHCCW as we only have one "local guy" (25 miles) and he doesn't stock very much.
2072 w/60" Haban
