Greg Rozar AKA- CubDieselFan
Old 11-13-2017, 09:54 AM
Lanceskene's Avatar
Lanceskene Lanceskene is offline
Default Did IH build a 16hp/manual trans???
Just thinkin ahead here for possible projects... I think I would like a WF, 16hp K, and a manual transaxle, possibly a 108 or 128 with an engine transplant.
Lance / Alberta Can
IH 127 w/deck, snowblade
IH 154 Loboy(x2) w/creeper 3pt and 3160 deck
CCC 12.5 w/deck
Plus 35 or so non IH tractors
Old 11-13-2017, 09:58 AM
The only 16hp Cub's I know of we're the 1606 and the 582, the 1606 was made by CCC and the 582 could have been made buy either. I've often thought about dropping a k341 in my 108 and getting custom 168 decals for it.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-13-2017, 10:31 AM
Lanceskene's Avatar
You should do it Tim, it would be a tough tractor.
It isnt very common to find 16hp GTs with a manual trans but Im old so Im old school... tractors are supposed to have gears and a clutch, add some HP and you got torque at the wheels.... I like torque👍
Lance / Alberta Can
CCC 12.5 w/deck
Old 11-13-2017, 10:42 AM
As soon as I can find an engine from a 169 I will, I don't want to buy a 169 just to take the engine out and k341's go for big money around here thanks to the pullers.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-13-2017, 10:47 AM
A 1535 should be about right for you. 18 hp Magnum twin with creeper gear.
http://www.tractordata.com/lawn-trac...adet-1535.html
If you feel like travel, I can put you on a nice one.
A long time ago, I put a 14 hp Kohler in my 108. Had a creeper gear in it. The 14 made more noise, vibrated more, used more gas and didn't do any more for me than the 10 hp did so I pulled the 14 after about 10 years and put the 10 hp back in the tractor. I'd guess a 16 would be a little noisier, vibrate more and use more gas than the 14?
Old 11-13-2017, 10:49 AM
What is the going rate for those engines in your area? Just curious.
Old 11-13-2017, 10:53 AM
Around here a running k341 can go as high as $500. There are several pulling clubs in the area and the pullers buy up all the bore bore engines.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-13-2017, 10:54 AM
Tim,
I was told that a 1650 Jacobsen engine has the same oil pan as a Cub Cadet,
but it would have a gear starter on it.
Up to 530 and counting...
Old 11-13-2017, 11:07 AM
Lanceskene's Avatar
I have 3 of those Jake 1650s right now, all in Ford blue, and Im taking the engine from one to put in a Lgt100 which has a Peerless 2300 transaxle... be interesting to have a comparable Cub👍
Lance / Alberta Can
CCC 12.5 w/deck
Old 11-13-2017, 11:24 AM
Lanceskene's Avatar
Thats an MTD built tractor so not what Im interested in... MTD however did build my ‘74 Columbia tho and its a 16hp with a Peerless 2315 transaxle, and it can do anything my 154 Loboy can.
File Type: jpg 278D022B-5162-42AB-9A22-1FFE0AEAA995.jpg (31.0 KB, 212 views)
Lance / Alberta Can
CCC 12.5 w/deck
