1650 with 44a mower deck questions
Been using my 1650 with 44A mower deck with the same belt for 4 years. I've never been comfortable with the tensioner or the description on the sticker about proper tension. I just recently replaced the PTO and was concerned I may have caused wear on it by improper tension. Is that possible?
The belt has always seemed loose, but the tensioner seems maxed. I've tried a few washers behind the nut to add tension to the point where the pulley hit the metal bar in front of it, obviously too far. So is it possible the belt has been too long this whole time? Also not sure about a proper replacement. I found a link in the forums, but it seems expired. What is the proper replacement? Is it common enough to find at a local home or lawn supply store? I apologize for the barrage of ?'s but the last thing I want to do is cause damage to the PTO or mower. Thanks! |
The pulleys should be the same distance from the front of the mule drive when adjusted.
Perhaps the belt you are using is a hair too long or really stretched out. Or you have the wrong belt for the size pulley on the deck. Info below copied from Cub Cadet parts lookup 44",50" W/4.5" PULLEY use IH-59971-C1 ************************* 3/8 X 78" 44", 50" W/5.0" PULLEY use IH-117465-C1 ************************* 3/8 X 79" NOTE: Belt, Mule Drive | -44A Mowers w/Serial No. 81741 and below on Tractors w/Serial No. 530,000 and above-except Cadet 1100 Tractors- 44A Mowers w/Serial No. 81742 and above on Cadet 1100 Tractors- -50A Mowers on Tractors w/Serial No. 530,00 and above-except Cadet 1100 Tractor |
Thanks. I'll order a new belt just to be sure.
Make sure you get the one for he size pulley that is on the deck
Have you checked your engine mounts? If they are totally shot the motor will sit low and make the belt seem too long.
FWIW, use a good quality belt, like those sold at your local dealer, because of the twisting, of going around the mule drive, cheap belts don't hold up.
You don't want the belt to tight. You'll be putting a lot of stress on the pulley bearings...
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Tractor is very solid. No rust. Garage kept since it was new. The only flaw is my inexperience.
I checked it out and readjusted the mower mount. Seems to me the locking bar was not totally in place (Quick hitch). This pushed the pulleys out of position and allowed the tension pulley to make contact with that cross bar (creating sparks). I couldn't create the tension I needed to transfer enough power. Determined everything was functioning ok and the belt is a bit worn from use, but still useable. This time I ran the motor and the PTO with the tensioner nut loose and pulled on the tensioner manually. It gave me a good idea where the pulley should be before I tightened the nut. Tightened the nut to that approximate place and fine tuned from there. I think I was looking at this floppy belt and possibly over tensioning the pulley. I have the notion that a long belt on bend should be expected to flop a bit. |
There should be a pair of snubber rubbers on the leading end of the engine rails. They are there to cushion the rails on the frame should the mounts sag a bit or if the belt is overtightened. Check and make sure they are still in place.
If they are gone, and your mounts are mushy, this would give the same effect as a too long belt. I would suggest you download and read the appropriate manuals for your tractor as well as the mower deck. Good info to have at your fingertips when the need arises. Good luck! |
This, happened on my 1450...
