Greg Rozar AKA- CubDieselFan
Old 11-09-2017, 04:40 PM
DieselDoctor's Avatar
Default Axle end play
While working on my Original, I noticed a fair amount of in and out play on both axle shafts. If you grab the wheel flange, you can pull the axle out and push back in about 3/8". This is the same on the opposite side as well. I've taken the housings off and the thick spacer washer is in place below the snap ring. There is no apparent wear. Is this normal? I could easily add a second spacer washer to reduce end play if needed. Thanks.
Old 11-09-2017, 05:28 PM
Perfectly normal
Up to 530 and counting...
Old 11-09-2017, 08:02 PM
Thanks Lew!
