#31
“Many of the truths that we cling to depend on our point of view”
#32
Alvy-Wan Kenobie has spoken the word of Cub Cadet
#33
Serial on the Kohler starts with D so that is 1968, and the tractor is 1964 so obviously not the original engine. Oscar Will's 50 Years of Cub mentions the 100 having a wide spoke steering wheel. But again, who knows what this little cub has been thru. Personally I don't know enough one way or the other. Didn't the size of the battery box change right around this model as well?
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
#34
According to the spec sheet in the 70/100 op manual, the 70 had a 5 quart gas tank and the 100 was 6.5 quart. Maybe that's a clue, if someone changed motors I doubt they'd also change gas tanks. http://ccmanuals.info/pdf/70-100%20O...r%20Manual.pdf page 25 |
#35
Check the head and see if it is a low boss one.
May have had the motor replaced. Gas tanks are not interchangeable .
#36
Lew - you mean high boss, low boss around the head bolts right?
#37
Yes lb on the bolt holes.
#38
Nope, just checked, it's a high boss head.
#39
Re 70/100 battery box. I had an early 70 many years ago and it had the smaller battery box, my early 100 has the large battery box.
#40
The model 100 could also be known for having stress cracks develop around the frame engine mount holes. My model 100 had those cracks, and I did find a lot of information on how to correct that problem. I tend to believe that not all 100's had cracked frames, but I do believe stronger that the model 70 has had nearly zero complaints about frame cracks. Also, my 100 had the large steering wheel commonly associated with the model 123.
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
Thread Tools | |
Display Modes | |
