If it is working, the white dial just ticks like a clock (to show it's running) It should run when the key is on. The red dial indicates hours 0 to 60, there should be a yellow dial which I can't make ot in your picture. Yellow dial indicates hours up to 600. Here is link to tech section info....
http://www.onlycubcadets.net/forum/s...ead.php?t=2931 |
If you can see where the yellow pointer is add 33 hours
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
The yellow is hidden under the red. So 3033 hours? So far it looks good for the years and hours. No battery or gas, so no start. But soon i think. Weather is turning wet and cooler.
Steve |
333 or 933 if it rolled over once. At 3033 it would probably smoke some
Useless
So the meter is useless for my information now. And that's ok.
Steve |
That is a nice looking 1000! It is a great find, especially at a furniture store.
I have only seen one. It is deteriorating at an outdoor power equipment shop. The guy wants $1000 for it. I think he will have it for a long time. Sad. |
Hour meter
Finally put battery in today, and the meter ticks when switched on. Starter cranks and motor sounds like it has compression. Still no gas, so not started yet. Soon!
Steve |
I could not stand not seeing if it will run if it's in my driveway,but that's just me lol . Good luck with it hope it starts right up!
Bob |
Life sometimes gets in the way.
Steve |
It lives!
Poured a little gas in, turned the key, and it fired right up, with no smoke or fuss. After a minute or so, pulled the throttle back to idle, and it just sat there chuckling. Tried the gears, and feathered the clutch. Again, no fuss! And, all for $225.00, delivered to my carport. Happiness is IHCC, again.
Steve |
