Greg Rozar AKA- CubDieselFan
Closed Thread
Old 09-17-2017, 08:38 PM
sluggomagoo's Avatar
sluggomagoo sluggomagoo is offline
Not really sure I care for your avatar pic. [/QUOTE]
Sorry I'll change it for you.
The drain plug shouldn't leak and you said yourself it was a problem item.
Old 09-17-2017, 09:09 PM
Your cranks haft seal shouldn't leak either, but sometimes they do. Power for the coarse.
The drain plug shouldn't leak and you said yourself it was a problem item.[/QUOTE]
sluggomagoo
Don't get J-Mech PO'd at you or you'll be in time out. How's things in Malloy land these days? I used to live in CT.
Old 09-18-2017, 01:07 PM
ironman's Avatar
ironman ironman is offline
A friend of mine has a MTD Cub GT about 10 years old (not sure of the model) but it has a 25 hp Kohler. He had the quick release fitting and one day while he was mowing the fitting jiggled open and oil got sprayed on the inside of the plastic hood and grill and it lit up. He got it out before any damage was done to the engine but the hood and grill were history. Maybe it was his fault or maybe it was the fitting but any time a I get something with the quick change fitting I change it over to pipe nipples and caps.
Old 09-18-2017, 03:13 PM
Yup, change the oil and by no fault of your own, all the oil leaks out and you end up with a pile of crap. Now that I know these things malfunction I want to go with a better solution.
Old 09-18-2017, 11:19 PM
Had a half a$$ oil drain similar, on a brand new $1,700 Vanguard go bad within the first season. It is what it is. You fix it, and life goes on.
A redesigned, now all is good...
Old 09-19-2017, 05:50 AM
The consumer deserves better then half a$$. Manufactures have been designing for over a century.
Not everybody has the ability or the skill to diagnose a simple problem that could result in a blown motor. Bottom line, if a problem happens under a warranty it MIGHT be covered if the manufacture can't prove user error. Everyone else can just shell out big bucks for a major repair or $2000 plus for a new mower.
Old 09-19-2017, 06:34 AM
Maybe you should lodge your "bitch" with Cub Cadet and their Engineers...???
Roland Bedell
Buy: Made in the USA
Old 09-19-2017, 09:02 AM
You are a prime example of consumer ignorance. You are just the type of person who doesn't understand that there are some parts of owning things that are just YOUR responsibility and not the manufacturers.
Take note: You own it. You bought it, and it's YOUR responsibility to maintain it. It will break. It will wear out. DEAL WITH IT. Things don't last forever. Especially cheap lawn tractors. Feel lucky you got 7 years out of it.
Old 09-19-2017, 02:04 PM
mortten mortten is offline
Jon- You were quite restrained.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Closed Thread
