Cub Cadet Original Deck Issue
Good morning! I am having an issue with my Cub Cadet "Original" mower deck. When I purchased the tractor, whenever I started it up the blades would be spinning (not good!) even when the deck was disengaged. I did some investigating and eventually found that both of the drive pulley bearings (not the spindle pulleys) were shot so I replaced them. I also found the previous owner didn't use the right length belt on the spindle drive (was 2" too short, which caused the engage/disengage plate to not have much travel - maybe 1/2"?). I replaced it with the proper length belt and adjusted the clutch rod length to make it shorter. I now have a good 1-1.5" travel length, which is what I want. Before I put this thing back on the tractor, does this look right?
https://photos.app.goo.gl/v7KbCRmlQLhbCZpw2 Video of it working engaged and disengaged by hand: https://photos.app.goo.gl/DtNBMUOZZR6nQfQs2 It still seems to want to drive the spindles. The spindles stop moving only because I have a block of wood under the deck and they hit it. Any help would be appreciated. Thanks! |
try it with the left belt cover on ,the shield under the cover should help, the belt being brand new would grip on the pulley more also
http://www.cubcadetcollectors.com/ma...geViewsIndex=1 What does the shield under the cover look like? All I can see is the top of the cover. If it's just bent metal, I can easily fabricate that. Can someone post the dimensions? |
