Greg Rozar AKA- CubDieselFan
Old 08-31-2017, 10:48 PM
TheFlyingCub TheFlyingCub is offline
Default 105 question
Alright fellas- I think I have one last question and problem to solve before I have a running tractor. Between the service manual and this site I can't thank you guys enough for all the knowledge I've gained on here.
So here it is- my hydro lever (speed lever) will not move at all. I have removed the cotter pin and clevis pin from the bottom of the speed control linkage to separate it from the brake rockshaft. I was going to remove the entire speed lever assembly from the bottom of the tractor. I then realized the speed control assembly is attached to the cam plate and associated linkage, ball joints, etc.
So I can't get it out of the bottom of the tractor
Does anyone know of an easier fix for this? If I look in the control tower I can see that the speed control rod and springs and things are a rusted mess and I've been soaking it it Kroil in hopes to free it up.
Any hints or help is much appreciated guys, lemme know what you think.
Old 08-31-2017, 11:11 PM
Keep soaking it. You have to get it freed up. If the shaft won't turn, you won't get it out the bottom, even if it fit, and even if you wanted too. If it won't turn, it's stuck.
Disconnect all the linkage from it so that you are just focusing on the part running through the dash. FWIW, I had a 125 a while back that was froze up when I got it. I had it freed up in just a few days soaking it with Kroil and trying to move it. You sure you don't have something else jamming the linkage?
Old 09-01-2017, 10:17 AM
I've disconnected all linkage possible. I'll keep soaking it and tapping it around. On a hydro tractor, should the speed lever be able to be moved freely with the engine off? AND not touching the brake pedal? I did notice before I disconnected the brake rockshaft and the bottom of the speed control linkage, the brake pedal wouldn't depress all the way, maybe an inch short of where the park brake lever could be engaged.
again, thanks for the help.
Old 09-01-2017, 10:29 AM
Terry C's Avatar
Terry C Terry C is offline
If the lever is froze not in the neutral, you can't depress the brake.
Keep spraying it, it will come. I've had several that came to me that way.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 09-01-2017, 10:56 AM
Terry and J - thanks for the help. Can't wait to have her running. Just to be clear, you should not need to press the brake to move the speed lever, it should move freely, correct? Never owned a hydro before.
thanks again
Old 09-01-2017, 11:26 AM
mortten mortten is offline
It should move freely. The brake pedal will put it back into neutral if the lever is in forward or reverse.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Thread Tools
Display Modes
